New Project for the new year by new member :)
Re: New Project for the new year by new member :)
Cool - glad to help
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Adding some 60 square meters of space to work and park
Rgrds
What other people think of you is none of your damn business
- sarel.wagner
- Pushrod
Finally got me aux driving lights
- sarel.wagner
- Pushrod
Steelwork complete
- sarel.wagner
- Pushrod
Done
- Has thanked: 19 times
Mooi man
Jy kan maar bel dan kan ons begin kyk na die chop job
- sarel.wagner
- Pushrod
Planning the bench and braai for the work area
Rgrds
Rgrds
- lowlight
- Been thanked: 14 times
Ek hou van die manier hoe jy dink, braai plek
- sarel.wagner
- Pushrod
Got my PIAA lights, Type 4 deep sump and some other goodies yesterday. Also did the simulation on the new Professional software for my Type 4 motor
Asked it to do some optimization, and this was the result. Currently doing an optimization run that will take a few hours to complete. It will tweak various things like cam timings, induction runners etc. and will optimize for torque.
Rgrds
I would be very keen to see how close your simulations are to the end result.
- sarel.wagner
- Pushrod
Tony, within a few percent, there is a post here where I did some simulations and predicted the power on a few T1 motors, unbeknown to me Impi had some of those on a dyno, the power difference was only a few HP, mostly less than 5HP if I recall correctly. With the new software it will be even more accurate as all the environmentals are taken into account as well as a host of other parameters like inlets, exhaust etc.
Rgrds
Rgrds
- sarel.wagner
- Pushrod
For me, apart from anything else, it is not how closely it will predict the HP/Tq but that it allows me to optimize the combination of parts. This allows me to buy the right Cam (or have a custom cam made to the best possible spec) valves etc, etc. and also get the porting done properly as well as set correct timing for the flow requirements. I can build the correct lenght and diameter inlet and exhaust, and do this only once
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Sold my Capri 1600 today, some more funding.... Also got the IRS pan picked up for the project, thanx Ruben
Started doing the engine building for the Type 4 standard motor in the Dyno software, for the 2.0L the max power and torque is within less than 5% of the published figures
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Crap, building materials are expensive! Ordered all the rest of the light fittings, plugs, wire, bricks, IBR and steel to complete the rest of the carport.
Please. Anybody got a contact for reasonable priced PVC roll up sides, like for lapas and used on Trucks as side covers? Need about 30 squre meters of the stuff.
Rgrds
Rgrds
- karmakoma
Love the way you work Sarel.
Go big or go home. Keep it up !
Braai is always a good idea close to the workspace
