Beetle type 4 twin turbo project
hennels
- What model do you have?: Beamish
- Has thanked: 3 times
Re: Beetle type 4 twin turbo project
dude... whaaaaaaaaaat? THATS INSANE! Good going. Cannot wait for more
Make a man a fire, and he'll be warm for a day... Set a man on fire, and he'll be warm for the rest of his life
- 4agedub
- Has thanked: 4 times
thanks
VW Beetle 1303 - 2165cc Turbo
VW Beetle 1971 2332cc
VW Beetle 1969 - 2666cc Turbo
VW Beetle 1974 - 1600
- HerVWturbo
- What model do you have?: 1962 VW Beetle
- Facebook: Reinhold Ortlepp
- Has thanked: 2 times
Hi mate.
What ever happened with this project?
Miss the SA beetle scene.
Hermann.
From Australia.
Hermann.
From Australia.
- 4agedub
It's evolved quite a bit, if all goes according to plan it will most probably run for the first time next month. I have added loads of photos on facebook, add me. Louis Cloete.
- Has thanked: 424 times
- Been thanked: 543 times
How about adding photo's and progress here please, we all love this stuff, and adds to our Forum Family info.
- 4agedub
- 4agedub
- 4agedub
So basically we changed from the original 72 body shell to a cleaner 69 shell during the build. The entire shell was paint stripped to bare metal and then primed.
The engine has been re worked with new Wiseco 4.060" pistons and a new engine casing to accommodate the Porsche cooling. We also opted for thicker barrels, The twin turbo setup was removed and was changed for a single Garrett GT3582R.
The intake system was reworked and individual throttle bodies installed.
- 4agedub
- Pushrod
- Been thanked: 111 times
I think you do know that you've created a monster!!!,.....and it is ALIVE !!!
Change your brass balls for titanium!!!!,.....you are going to need it!!
- Has thanked: 45 times
- Been thanked: 208 times
Looking nice those Deutz cylinders.
What boost pressure do you plan to use?
- 4agedub
Yes they are Deutz thick wall cylinders with 4,060" bore (103mm). Static compression is at 12:1 and the wastegate spring is 7psi (0.5bar)Dawie wrote: Mon Mar 11, 2019 11:15 am Looking nice those Deutz cylinders.
