dude... whaaaaaaaaaat? THATS INSANE! Good going. Cannot wait for more
Re: Beetle type 4 twin turbo project
Posted: Thu May 30, 2013 7:54 pm
by 4agedub
thanks
Posted: Wed Mar 28, 2018 5:25 am
by HerVWturbo
Hi mate.
What ever happened with this project?
Miss the SA beetle scene.
Hermann.
From Australia.
Posted: Wed Mar 28, 2018 7:42 am
by 4agedub
It's evolved quite a bit, if all goes according to plan it will most probably run for the first time next month. I have added loads of photos on facebook, add me. Louis Cloete.
Posted: Wed Mar 28, 2018 9:07 am
How about adding photo's and progress here please, we all love this stuff, and adds to our Forum Family info.
Posted: Fri Mar 08, 2019 10:30 am
by 4agedub
Posted: Fri Mar 08, 2019 10:32 am
by 4agedub
Posted: Fri Mar 08, 2019 10:42 am
by 4agedub
So basically we changed from the original 72 body shell to a cleaner 69 shell during the build. The entire shell was paint stripped to bare metal and then primed.
The engine has been re worked with new Wiseco 4.060" pistons and a new engine casing to accommodate the Porsche cooling. We also opted for thicker barrels, The twin turbo setup was removed and was changed for a single Garrett GT3582R.
The intake system was reworked and individual throttle bodies installed.
Posted: Fri Mar 08, 2019 10:43 am
by 4agedub
Posted: Sun Mar 10, 2019 12:58 pm
by Haans
I think you do know that you've created a monster!!!,.....and it is ALIVE !!!
Change your brass balls for titanium!!!!,.....you are going to need it!!
Posted: Mon Mar 11, 2019 11:15 am
by Dawie
Looking nice those Deutz cylinders.
What boost pressure do you plan to use?
Posted: Tue Mar 12, 2019 2:32 pm
by 4agedub
Dawie wrote: Mon Mar 11, 2019 11:15 am
Yes they are Deutz thick wall cylinders with 4,060" bore (103mm). Static compression is at 12:1 and the wastegate spring is 7psi (0.5bar)
