I really feel ashamed that the last time I worked on this project was in August last year. (Fortunately) Work interfered a lot, which I am thankful for, but it also meant all my projects had to take a backseat. Besides work, engine problems with the Syncro, my normal daily driver, also forced me to spend some time on Ugly Betty (aka the Life saver) to make sure that she runs without problems. She obviously has performed this task beyond the call of duty.
So at this stage it looks like I'll have some time at home during March and hopefully at that time I'll get some more work done on the cabrio. The SYncro is still at the top of the list, but in between I should have some time to spend on the bug.
Since the last time the only thing I have done was mount the rear discs properly.
The list of outstanding work is still pretty long.
1. Install master cylinder and find the fluid reservoir.
2. Install new brake line
3. Fit brake pads front and back
4. Fit crystal headlights
5. Fit stainless firewall kit and insulation
6. Tighten rear axle nuts
7. Fill gearbox with oil
8. Install gauges and sensors
9. Check electrics and wiring
10. Fit windscreen
11. Buy and Fit seatbelts
12. Modify side mirror mounts
13. Colour code and fit side mirrors
14. Fit door window scrapers and rubbers
15. Turn rear suspension 1 spline
16. Fit new column switches (indicators and wipers)
17. Fit steering and boss
18. Install shocks
19. Fit release bearing and guide tube
20. Fit Clutch and pressure plate
21. Fit Battery
22. Engine (Has to be built)
23. RWC and license
Some cosmetics I would like to add
24. Stone guards and kickplates
25. Door and hood handle scratch guards
26. Alarm and central locking
27. Sound installation
28. Interior lights
29. Pedal covers
30. Center console
So let's hope I can update this more during March with a lot scratched of the list.
