That I know yes the more dense and cold the better, intercooler makes a use difference and allows more boost without detonation etc. Effieciency range I am close to but can push the boost a little more without compromosing that.
Sorry Bratjie don't want to hi-jack. Did you calculate your engine flow etc on a turbo map for the waterboxer?
Mild 1600TP Turbo engine
- Wentzel
- Has thanked: 6 times
Re: Mild 1600TP Turbo engine
Oxyboxer Project
- Bratjie
- What model do you have?: 74
- Facebook: https://www.facebook.com/juan.buter
- Has thanked: 3 times
- Been thanked: 5 times
Hi, no problem mate, I calculated 377 cfm or 26.39 lb/min or 10.7 cm/min, the following turbo's would be suited : Garret GT2056, GT 2252 etc, but I'm slapping on the T3 that the engine came with and check it out from there, holding thumbsWentzel wrote:That I know yes the more dense and cold the better, intercooler makes a use difference and allows more boost without detonation etc. Effieciency range I am close to but can push the boost a little more without compromosing that.
Esté robusto, ser fuerte!!!!
73 Beetle project
73 Beetle project
