My 356. Now sold.
- Has thanked: 36 times
- Been thanked: 50 times
Re: My 356 Speedster
good news..............
Screw that, as soon as people have a look at my car when I take it to have some stuff and stuff measured I can almost see them drooling. Not going to happen on so many levels buddy.
- acpaterson
- Has thanked: 80 times
- Been thanked: 131 times
I hear you..
So, for now, I'm done. will attempt to find other contacts in Cape Town who WANT business.. Keep us update don the roof pls man.
Alan
Alan
- Muderick
- Has thanked: 42 times
- Been thanked: 69 times
Hi Alan...
A few things?
* You are not going to find a better tuner for those carbs than jESSE hUGGET. He has been racing beetle engines for 35 - 40 years.
* If you do not wanna leave your car and keys there... why not wait for it while he works on it? Should solve the issue?
* Your cable looks a bit tight in the throttle tube and will eat into the tube... try getting one of these KITS. They give the best performance for dual carbs anywhere!! I HAVE USED THEM FOR A FEW YEARS
http://www.thesamba.com/vw/classifieds/ ... ?id=786740
A few things?
Old School or Bust!
^^^^nifty idea............way less abrasive edge that the cable is now running on.
- Muderick
It is a brilliant piece of kit Gary...
Its made from aluminium, except for the stainless steel roller wheel. The throttle tube is also lined with a silicone insert, and can either be rivetted onto your fan housing or screwed on with the supplied screw.
Make sure to order the barrel end clamp seperately as it does not come in the kit.... just makes it so much neater.
Also, Joe the supplier is a top guy and orders arrive in about 10 days via normal USPS first class mail.
Muds
Muds
Old School or Bust!
- acpaterson
That is cool.. I'll attempt a DIY.. 600 plus bucks for something THAT small doesn't go down well boet. Mine "looks: like it's cutting into the tube, but I'd hammered my tube to get that flankge piece as flat as possible.. The tension's not much on the tube, and if I DO replace the motor and new tin, I'll redo the mounting and lift it slightly so it doesn't have any angle on the cable.
As for Jesse, yes, I know his history and I've always been a fan. he worked on my street Bug years back.. But I can't leave the car for 2 or 3 hours un-attended.. I also can't take time off work to wait for him? Not serious, I'm going to hook up with Tony sometime in the next few weeks and will sort mine out. For now it's running pretty well actually, no more issues currently at hand.
Outstanding issues for now are things I can do as and when they are found, steering wheel, roof, carpets, spray painter.. there's a list as it is with all our refurbishments and toys ..
regards
Alan
regards
Alan
- Mustang Sally
- What model do you have?: Porsche 356 replica
- Has thanked: 7 times
- Been thanked: 2 times
Hey Alan
Your thread is becoming a goldmine!
Thanks Muderick for the link. The cable on my twin carb setup has been bugging me endless and this seems like the perfect solution. Have contacted Joe and roller is on it's way.
- Muderick
Well done Mustang Sally... see Alan... u could have shared costs.... he normally sends them in an envelope, so postage is cheap.
Muds
Muds
Old School or Bust!
- acpaterson
No worries,
took me an hour to make my own. does the same job, cost = a few ronds..
Thanks anyway Muds, I know you're only looking out for me\us, so it is appreciated boet.
regards
Alan
regards
Alan
pics..................common, you know how it works in here. Spread the wealth.
- acpaterson
- acpaterson
And, this coming Saturday, we have a rendezvous with forum member Tony Z to meet and greet, and to have his professional eye and ear pour over my twin carbs. and to help set 009 Disti.. Then on the way home, stopping to meet possible spraypainter. So, it's almost all done for my little car.. whoop whoop.
regards
Alan
regards
Alan
- acpaterson
Thanks to Mudz' earlier post, here's my take on the Accelerator cable roller thingie..
Bent a piece of steel bracket. Used a small long bolt and lock nut. Piece of round Ali rod, ground a small "dent" to help center the cable, and the put some grease on it. Considering how much tension is being drawn across this item, it's negligent really, and should do any damage anyway.. But it was a challenge for me to make one..
Nothing against some solid machining of Aluminium etc, but when it's R 600-00 plus for something THAT SMALL, then I have a problem with it.
regards
Alan
regards
Alan
- Speedy356
- What model do you have?: Porsche 356 (Rep).
- Location: Dinokeng Nature Reserve, Pretoria (Dont know where the hell "Tswane" is!).
acpaterson wrote:Thanks to Mudz' earlier post, here's my take on the Accelerator cable roller thingie..
Bent a piece of steel bracket. Used a small long bolt and lock nut. Piece of round Ali rod, ground a small "dent" to help center the cable, and the put some grease on it. Considering how much tension is being drawn across this item, it's negligent really, and should do any damage anyway.. But it was a challenge for me to make one..![]()
regards
Alan
Yes it is a replica, but it is mine!
Remember......Drive it like you stole it!
Beware of stupid people......Especially when they congregate in large groups!
