Page 17 of 53
Re: 1.5 KCC 356 Porsche Speedster
Posted: Tue May 27, 2008 7:47 am
by vuyo
wa wa wi wa i like!!!!
Posted: Tue May 27, 2008 8:02 am
by Pine
From http://www.356registry.org/tech/vwtoporsche.html
The license plate light assemblies for 1960-65 are the same as those used on the early Mercedes 190 and 220 series
Dunno which ones you're looking for, these directly below the license plate?
The 'S' and 'SE' models have a different setup at the rear (pic to the right)
This one is on EBay for $ 30, but it looks different:
Posted: Tue May 27, 2008 8:08 am
by flatfourfan
I think the later unit is the style that I'm looking for. I think that I should start looking at older US cars.........
I saw these ones that would look good on a 60's 356, I want the larger unit though.
Posted: Tue May 27, 2008 8:24 am
by Pine
Isn't this the license plate lights you want?
Image[/quote]
Posted: Tue May 27, 2008 8:44 am
by flatfourfan
Nope I want the larger one that is mounted on the car itself.
Those ones that you posted came off the 60's 356c's I believe.
Posted: Tue May 27, 2008 1:57 pm
by Pine
Take a Type 3 license plate housing and mount it upside down?
Posted: Tue May 27, 2008 2:08 pm
by flatfourfan
lol, and now to find a type 3
Posted: Tue May 27, 2008 11:24 pm
by Bugger
You really want everyone to see your registration plate at night :zhelp: :D
Posted: Tue May 27, 2008 11:31 pm
by Chris
This one?
Posted: Tue May 27, 2008 11:35 pm
by Pine
Hey all those badges are blocking the air flow to the engine!! :shock:
Posted: Tue May 27, 2008 11:39 pm
by Rabid_ant
ah ha....fear not lads.....Mr G is almost 100% correct. the restorers extract reads......
"At coupe 100001, cabriolet 61701 and Speedster 83201 (tailight change) the license light went from shine-down to shine-up, under the license plate" based on my esteemed restorers manual, this was introduced at the same time "the tear drop tail-lights appeared, combining tail light, turn signal and brake light"
So there you have it :)
Posted: Thu May 29, 2008 8:02 am
by flatfourfan
lol..................Well mine is going to be a mix match of a few years parts, I'm even thinking of keeping my pre-A beehive tail lights, but we'll see, if I don't like it, I can fill them and add the tear-drops.
Posted: Fri May 30, 2008 10:51 am
by BARON
Gary,
Some dash board question if you can help.
1) Did your friend Willem do your dash board if so will he do a 911 dash and what will it cost more or less (the base is f/glass)
2)Is that real leather or vynel ----Where can one get real leather thin enough to work with a normal sewing machine.
3) Did you glued the leather onto the f/glass or did you do something else
cheers
Baron
Posted: Fri May 30, 2008 11:32 am
by flatfourfan
Baron
1) Willem is working off my existing dash pad, but it's really not that serious a job to do, but he would the actual car as no doubt a dash pad would have to be made from poly first and then glassed, not an easy job, but do-able.
2) On the dash i'm putting leather, I bought 4 hides a while back that I wanted to use on this project, I have an interior guy who's using industrial equipment to do this. I have no idea where you can get thinner leather.
3) It's not done yet as Willem has to finish off the pad, but we're going to glue it on.
Cheers
- G
Posted: Fri May 30, 2008 9:02 pm
by Bugger
BARON wrote:Gary,
cheers
Baron
You have to send the cow to the abatour when it is still un educated coz as soon as they get educated they get thick skinned :D
