Fuel injection rebuild
- Been thanked: 5 times
Re: Fuel injection rebuild
The replacement pushrod arrived in the mail today! (Despite the delay, it was actually pretty painless)
Already cut and waiting with the others!
Whilst waiting for my exhaust and some powder coating done, the oil cooler has been cleaned and prepped. Also decided to tackle the gearbox this weekend, so started with draining the oil and then cleaning.
Oil cooler good to go:
Working around the suspension and gearbox will now be a much more pleasant task.
Two questions though... The Bentley manual says there are two magnetic plugs to pull for drain, but I only see one? Is the other the filler?
And when replacing the boots, the manuals indicate orienting the split horizontally, but most people seem to incline it a little. Any reason for the deviation?
Think some box's have an for and an aft plugs, the filler is on the side halfway up / or halfway down depending how you look at it.
The reason you place it at 45 Deg angle from the top facing back, is that if not properly sealed, the oil can not run out and the water splashing from the road will not be forced in.
THanks for the info. I am assuming that the boots can fill to above the mid-point with oil, hence people incline them at 45deg instead? Just seems to me that horizontal places the least amount of stress on the boot, which should allow them to last longer?retrovan wrote: Sun Oct 06, 2019 9:20 pm Think some box's have an for and an aft plugs, the filler is on the side halfway up / or halfway down depending how you look at it.
put them horizontal and make sure they dont leak... thats what I do
use sealant on the halves
- AlanH
- Has thanked: 123 times
- Been thanked: 86 times
And don't overtighten the clamps. If you tighten them too much it will leak.
Wanted parts:
Left sunvisor
Sink faucet
Left sunvisor
Sink faucet
Got a bit distracted last week, but got my powder coated parts back. They bent a lot of it in the process, but I have largely rectified it. Will post pics this evening.
Got the boots off and clean it up a little more, but the kit I have is missing a set of the small clamps. Will need to get a set of stainless ones during the week.
Otherwise, all the fuel lines are now finished, and the alternator is prepped. Any feelings on the amount that just be threaded in? In order to get the 2mm clearance behind the impeller, I have shimmed it rather high. And the. With the spring washer there is only about 6mm of thread engaged with blue loctite.
mount it on the fanhousing and adjust accordingly. You want the fan as far forward (towards the driver) as possible, without it rubbing.
Thanks Tony. I decided to ditch the spring washer which will give me some room to maneuver. Red loctite will serve as it's replacementTony Z wrote: Mon Oct 14, 2019 12:12 pm mount it on the fanhousing and adjust accordingly. You want the fan as far forward (towards the driver) as possible, without it rubbing.
Some pics as promised...
... of the coated valve covers. Matt black for heat transfer, as opposed to polished silver before.
Mock up of the front tin with fuel fittings. I feel a little more clearance around the louvred trim is necessary, but at least it all fits in.
And the front tin with the cut out for the oil filter return. Unfortunately it creates a bit of a gap in the tin, but it will have to do.
New Jtubes will hopefully come late this week and then I can finalise the mock-up process and move on to cleaning and final assembly.
- What model do you have?: 1600 off-road thing
- Has thanked: 34 times
Looks damn good Simmy!
- Riaan.N
- Oil Seal
- Has thanked: 3 times
- Been thanked: 38 times
Maybe you put some of that u-shaped rubber on the tin?Simmy wrote: And the front tin with the cut out for the oil filter return. Unfortunately it creates a bit of a gap in the tin, but it will have to do.
That's the plan, but will only fill some of it. I know it's pedantic, but hey... Unfortunately I am not much of a welder, so closing it up with sheet metal was never going to happen.
