Re: suicyde engine
Posted: Wed Mar 24, 2010 5:29 pm
progress has been slow and hampered by the recent discovery of a seatcover who cant get enough of me...
I have so far had all the hoses off to check for blockages - none found.
Drained the oil and removed the add-on sump to allow access to the pressure relief valve - valve moves freely.
Re-assembled everything.
changed the oil filter for good measure - this one was less than 100km old but it got changed out anyway - cheap insurance.
Lots more thinking pushed me towards considering that my additional oil piping, new cooler and thermostat could be to blame. The minute you add more piping and any bends, the pumping losses increase... so I could have unwittingly added bits on to the point where once the thermostat was fully opened, the 26mm pump was unable to supply the demands of the engine.
Yesterday I removed the 26mm oil pump and installed my 30mm oil pump. Then when I went to swing the engine over to check for pressure, I was greeted with a flat battery.
Today I swung the engine over until I got pressure and started the car. Fired up immediately and pressure under idle with cold oil rose to 2.5bar. At 2000rpm its now sitting at just over 3 bar.
Tomorrow is test drive day.... hold thumbs.
