I will allways advise when ordering when I know the quality is an issue, there is allways another option, but one thing is for sure most of the time the cheap option is asked for, and in that case don't complain when you get a cheap, shitty quality item. Remember that you will allways get what you pay for, there is no such thing as good quality & cheap.
- Been thanked: 98 times
There is Empi stuff that is good and bad, you need to know what is what, some chineese made bits are crap
, and one allways needs to make a plan to make it fit or the quality is shoddy. One needs to rememger not to generalise as Empi sell quality German stuff too.
- davetapson
- What model do you have?: Type 1's '63 and '66
- Facebook: www.facebook.com/davetapson
Well, it seems that golfs also have 30 PICT carbs and the gaskets are not the same - most of the rest is so you only find out when you get to putting the top of the carb back on the body...davetapson wrote: got kit from Sonny's. Ceramic heater on side of carb is cracked, but will reuse it. The plastic dish that the heater fits in I cracked removingbut will fix with epoxy this evening.
So, I've set the points, have statically timed the car, and I reckon when I get the carb back on, it will start no probs. Will wait and see...
And of course I chucked the till slip and mixed up some epoxy glue on the box, so in all likelihood I can't return it... bugger...
- Hloni
- Has thanked: 14 times
- Been thanked: 11 times
6 weeks later, no sign of any flaking or rust coming from battery bay. That NS stuff is 'da bomb'Ron&Gill wrote:Tell me how you made out...Hloni wrote:Sure for that R&G, am goin' into the city today to get the stuff. Might also get NS1/NS2 which Chris swears byRon&Gill wrote:Wash the area with caustic to neutralize the acid, then with soap and water, don't spare the water. (the solution to polution is dilution) Use the caustic, you know what happens to your jeans when you get acid on them, everytime you wash them, the hole gets bigger! This only stops when you soak them in caustic, why should your battery tray be any different......
Man didi what a man had to do just before sunset today. Will see what she looks like tomorrow once the sun has risen.!!
mahleu
Drilled some holes to let the water out
Life begins at 80 and ends shortly after in a temporary court on the side of the road.
- Tristram
- What model do you have?: 1974 luxbug
Just whipped the tappet covers off and put a spare set of pretty gold cadmium plated covers on with new seals. No more oil leak, lets see where the next leak springs from.
Tristram
1974 LuxBug 1600 AKA PIG
"Im a slave to my aircooled"
- JamesD
- Been thanked: 20 times
Finished my back board with my sony 6x9's in and the hatch in the middle to put my laptop bag in... Plywood with aluminum reinforcing.
From fastest to slowest:
'75 SP 1600 with a few mods
Perfect!JamesD69 wrote:Finished my back board with my sony 6x9's in and the hatch in the middle to put my laptop bag in... Plywood with aluminum reinforcing.
I adjusted the valve clearances on the Khaki Cruiser. The engine was a bit noisy, and VW suggested a valve clearance adjustment every 5000 miles (more or less 8000 km) in the old days anyway.What did you do on your car today?
I have found the following method the easiest for myself:
- Put the car in 4th gear, and jack the right rear wheel up
- Remove the right-hand side valve cover (no 1 & 2 cylinders)
- Get TDC (top dead centre) by turning the right wheel of the car till the rotor points to to No 1 cylinder plug lead, and the timing marks are aligned
- Adjust the No 1 cylinder valve clearances intake and exhaust b.m.o a feeler gauge and flat screwdriver (the Type 3 bible says 0.1mm or 0.04 inch)
- Re-check the clearances after the 13mm nut is tightened
- Turn the right rear wheel 180 degrees backwards
- Repeat the procedure on the No 2 cylinder
- Close the right valve cover
- Lower the car, and jack the left side up
- Turn the left rear wheel 180 degrees backwards again (or till the rockers are not moving)
- Repeat the process with the No 3 (left front) and 4 (left rear) valves
- Close the valve cover, lower the car
- Take the car for a test drive and check for (new) oil leaks on the valve cover gaskets
After I followed the above procedure this morning, the engine is noticably more quiet and has a definite increase in power!
Sat morning got the DC out of hiding and removed the motor that had no more vroem vroem in it The Vrou was the appy and things went quite well I wanted to install the 2nd hand motor that I managed to source for the DC But could not find Engin mountings close by
so will rather have the Flywheel scimmed and get some mountings in the week to re install the 1.9WBX motor
I am looking for the Pictures Hubcap has posted of the different engin mountings
The links that I have searched does not open any one got the link
- Dutch_Diver
Do you have any pictures of the shelf with measurements? I would love to make one of those for Rosie!JamesD69 wrote:Finished my back board with my sony 6x9's in and the hatch in the middle to put my laptop bag in... Plywood with aluminum reinforcing.
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Well done Bugger. That is really aBugger wrote:Sat morning got the DC out of hiding and removed the motor that had no more vroem vroem in it The Vrou was the appy and things went quite well I wanted to install the 2nd hand motor that I managed to source for the DC But could not find Engin mountings close by
Are you putting the same engine back?
I have those mountings for you Pierre, if it's the ones that attach to the engine mount that bolts onto the casing. Not that clued up with WBXs... Will see if i can find them and take some pictures...
BF I swopped the 1C Toyota Diesel motor and Bell housing that I had for a 2nd hand motor that a friend of mine had laying around for a baywindow bus
I also have not had a chance to get Betty sorted are driving her a bit to get more KM on but mostly just around here the oil temp has not gone past 80 yet show you the short distances but she is a bit shitty to drive but getting to know how
I will be checking the timing as that might be not right which can cause the hard start and flat spots but then after that I will visit SP again
Blitz I need those mountings Quite urgent have a look and let me know I will be hunting ones close by aswell
Give me a miss call when you got them
I will also phone one of my other suppliers tomorrow that is close by
- JamesD
Thanks Pine
I'll try help Dutch, I'll take a few more photo's which will give you a few rough measurements. I haven't put the sound proof foam on the bottom side yet so i'll post a pic of the bottom, shows all the detailed work still. the vinyl covering is the hardest part, what with the hinged hatch...
Hoodrider
- What model do you have?: 1967 Sunroof Bug
body filler and more body filler and sanding to bonnet tailflap and arches.
Hoodride.......... Because nobody is perfect....
