Page 20 of 21
Re: Scrappy the beetle (Back In Action)
Posted: Thu Jul 26, 2012 5:45 pm
The hardest part of a
job, is kicking yourself.
This is what they call "School Fee's", and boy, does it heart.
Posted: Thu Jul 26, 2012 9:57 pm
by Junior
Posted: Fri Jul 27, 2012 7:53 am
by Ron&Gill
Good luck with those exams there...
Posted: Fri Jul 27, 2012 8:00 am
by Junior
Posted: Sat Jul 28, 2012 5:26 pm
by Junior
Sub assembly almost together again... feels good knowing its done properly
Posted: Mon Jul 30, 2012 7:44 am
by MarshallGTi
well done dude...
Posted: Sun Aug 12, 2012 5:55 pm
by Junior
Okay, after a few squished fingers and the invention of a few new swear words... I have got the motor back together and into the car. There is oil pressure but I can't start her up, because of me changing from a Genny to an Alternator the carb does not fit. I'm going to try make a spacer and pick up some new, longer studs tomorrow. Then I can see if it will start up again
Posted: Thu Aug 16, 2012 9:19 am
by Junior
I spent the whole day yesterday shopping for a beetle for a friend and eventually found one
I am now waiting for the spacer for the carb to be laser cut, and hopefully it should be here but this afternoon or tomorrow morning
Then the rear lid has been sprayed with undercoat and I can start buffing it for paint. As far as the rear fender go, I was going to try get some from someone in PE but he is in hospital so I will have to get them some other time...
Work is going slowly but its getting there, I should be at home for the next while so hopefully I can get some work done
Posted: Thu Aug 16, 2012 8:37 pm
by Junior
Discovered that the Fuel pump has packed up. So I dug out a spare and cleaned it out and put it on. The spacer has still not arrived so I can't put the carb on but I finished painting the engine lid and it looks good
I have to write my NBT's on Saturday so I can't do any work then but hopefully I can make up for it tomorrow and on Sunday...
Posted: Fri Aug 17, 2012 8:10 am
by MarshallGTi
how bout sum pix of that there deck lid?
Posted: Fri Aug 17, 2012 5:58 pm
by Junior
I will post some pic's on Sunday afternoon, hopfully I will have the engine lid on by then...
Today, I did the following...
Gave the engine lid a few more coats of paint
Painted the rear apron
Welded a few patches on the rear right fender
Replaced the 6v wipers with a set of 12v (made a mounting bracket)
Set the timing, valve clearance and points gap
Finished putting on the exhaust
Mounted the petrol tank
I went to go fetch the spacer for the carb to find that the holes for the studs have not been drilled, so it looks like I have to wait till Monday before I can mount the carb and run the motor in...
Posted: Sun Aug 19, 2012 2:52 pm
by Junior
Here are the pics as promised.... the lid is not bolted on and that's why it looks skew
O and just so you know that is my 75's oil stain under the car.
Posted: Thu Aug 23, 2012 6:59 pm
by Junior
I finally own 2 running beetle's
Scrappy is running really really well, but I can see a slight oil leak starting at the 3rd push rod on the left which is a bummer.... now that I raised the carb the air cleaner doesn't fit
and I have also had a major problem with fitting the deck lid, its LHS mounting bracket has a big hole in it where there is meant to be a bolt hole... so I have to short that out some how.
I'm picking up a set of rear fenders on Tuesday an I'm going to be away for the weekend. once I have all 4 fenders on and the running boards I'm going to be really happy.
Posted: Thu Aug 23, 2012 7:25 pm
by hitlers revenge
Why Oh! Why are you using that 4 into 1??????????????????????????????????????
Posted: Thu Aug 23, 2012 9:18 pm
by Junior
Ya, I did not want to use it either... but when you don't have the cash for a new one there is not much I can do, and the motor is a 1200 which means that I would have to buy a new one again when I have the cash to convert it to a 1600... For now I just want to get it on the road then I can start spending money on fancy new exhausts
While I was looking at some beetles the other day, someone had just cut off the silencer and replaced it with a golf's one and it sounded really good. I was considering going to look in some scrap yards to try find a decent silencer. Any thoughts?
