mahleu
Post by mahleu »
Replaced a broken battery terminal connection and put in a scary amount of oil and water. Also put a diplomatic piece of cardboard underneath to catch leaks :idea:
Life begins at 80 and ends shortly after in a temporary court on the side of the road.
Cyberbeast
What model do you have?: 1974 Beetle
Post by Cyberbeast »
Washed my car today... looks good once again...
© CB ©
lowlight
Post by lowlight »
Nothing. Come home tonight, no power,sit with laptome and candle power. :D
Dirk
Post by Dirk »
Made a set of white reflectors for Christn. Much the same way I did for Lady.
`68 Beetle
`66 Fastback
'90 Sunpacer
Post by 1972 »
Dirk wrote:Made a set of white reflectors for Christn. Much the same way I did for Lady.
oh dirk to tell us how do tell
Dirk
Post by Dirk »
Shane, they don't look at all the same as the original ones. They are simply about the same size.
I've taken photos and will post the story on my site. Will let you know when it's done.
`68 Beetle
`66 Fastback
'90 Sunpacer
Dirk
Post by Dirk »
Shane,
I've posted it, you can read about it here: http://djb.co.za/?q=node/29
`68 Beetle
`66 Fastback
'90 Sunpacer
Post by 1972 »
thanks Dirk
lowlight
Post by lowlight »
got metal pipe that goes from reservoir to the master and bleed brakes. Really helps if there is a second pair of feet around. Had to do it on my own. Tonight another romantic night without power.
Dirk
Post by Dirk »
Took the fasty gearbox appart so I can send it to get Buggered :twisted:
`68 Beetle
`66 Fastback
'90 Sunpacer
Dirk
Post by Dirk »
Today I cut new top-front door panels for Christn. I ran out of hard-board so I could not do the rest. But then I turned my attention to the parcel try. Striped it and started sanding it down.
`68 Beetle
`66 Fastback
'90 Sunpacer
Hloni
Has thanked: 14 times
Post by Hloni »
Took her out for a dougnut session, now engine is blinkin dusty! ah... :bn:
3011
Dirk
Post by Dirk »
Did an oil change on Lady this morning. I swear she smiled at me when I was done :) noting how much better I've become at it since doing my first one about a year ago.
`68 Beetle
`66 Fastback
'90 Sunpacer
Post by 1972 »
i spent my day on the start of a body roller for my beetle more to come in my build thread later :wink:
Dirk
Post by Dirk »
Dropped off Christn's gearbox at HR's, then came home to put Lady's repaired right rear wheel back where it belongs. The spare wheel is also back where it belongs.
Then I left Lady wide open in the sun so she can get rid of some of the trapped moisture in her.
`68 Beetle
`66 Fastback
'90 Sunpacer
