My 1974 single cab fleetline wide load splitty
louisvr45
Re: My 1974 single cab fleetline wide load splitty
Post by louisvr45 »
rusty bulkhead
louisvr45
Post by louisvr45 »
My wiper axle fixed
Good one Louis, where was the wiper axle broken,how did you fix it?
How much rust have you got on the body apart from the area behind the cab?
louisvr45
Post by louisvr45 »
jolas wrote:Good one Louis, where was the wiper axle broken,how did you fix it?
Hi ive cut out that panel and fit a 1.6mm sheetmetal over
And on the wiper axle ive cut of the broken shaft and punch out the other shaft in the tube. Then fit a 6mm steel shaft., cut 5mm threat and put sum nuts on. I'll post pic of it later
louisvr45
Post by louisvr45 »
Who would lower a bus this height?
adjusting the valves
all put back and cleaned
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
You can lower your bus by putting in some adjusters, Diesel electric sell vdo gauges and senders
louisvr45
Post by louisvr45 »
splitfan do you have their nr?
I would mayby raise my height not lower it.
louisvr45
Post by louisvr45 »
some more pics
interior door panel
front pan
wide bed
side drop side
rear drop side
fleetline sticker
Rear bumper
over riders
mounting brackets
Nice one Louis, keep at it :hangloose:
louisvr45
Post by louisvr45 »
thx jolas.
for those of you that asked about the wide bed.... here it - stil have it - want to replace the main loading area and cut and fix all the rusted parts
Louis, that widebed floor does'nt look that bad, I've seen far worse. Do you still want to keep the profile of the floor original. Maybe you should see whats available before you hack into that floor.
Whats the condition of the load bed floor on the pick-up
itself?. When I replaced the loadbed floor of my bay window SC, I found a guy in Montague Gardens who made a very close profile.
However he was'nt keen on making sheets for my widebed floor (which is ok now as I scored one from Eugene a while back).
Here's some pics of the floor made up for my '74 SC. I messed up with the rivets though, spoils the whole finish :(
louisvr45
Post by louisvr45 »
hi,
I would like to keep the org profile but I'll see what I can do but 1st fixing the sheeting below and some hindges
then I want to put more reinforcing on the wide bed...
louisvr45
Post by louisvr45 »
my new gauges : oil pres, oil temp, rev counter
louisvr45
Post by louisvr45 »
my bulkhead got some self etc primer:
one of my ideaS of placing my new gauges
Junior
Post by Junior »
Please Dont drill any holes in the dash :zhelp:
