Page 3 of 13
Re: Project Fleetline
Posted: Tue May 24, 2011 2:10 pm
by sean
I still need to find the front tinware for my motor, the one that will sit below the fuel tank when installed. I have tried finding out the differences but I have been told it is different between beetles and splits and different between single port and twin port.
I have a 1600 twinport motor, is this front plate specific for a fleetline bus?
Is a twinport the correct motor for a fleetline?
Posted: Tue May 24, 2011 8:58 pm
by fig
There's no difference between the front engine tin on a Beetle and a split bus. The tin is different between single and twin port (twin port has a cut-out for the oil cooler air outlet; you can cut a SP tin in need). The early type1 engined baywindow buses have a different front tin to the Beetle; it stands a bit higher. You can see how VW simply welded an extra bit on top.
Posted: Tue May 24, 2011 9:50 pm
by sean
Thanks Fig!
Posted: Wed Jun 01, 2011 12:23 am
by sean
Installed the motor in my fleetline this past weekend and took it for a drive.
Check out the video clip.
http://www.youtube.com/watch?v=Ob-EoOYW7qQ
I was keen to see if the gearbox was still ok as the nose cone had been smashed off and all gearbox mounts were broken obviously from someone hitting it on something underneath, replaced all of those and luckily all is still good. Gears are crisp and no noises at all. All the components will come out again at the end when I do the full rebuild underneath but at least it was some sort of progress compared to just the body work over the past few years. The engine is such a breeze to install compared to the type 4 motor in a baywindow and that removable engine rear panel makes life easy too.
It really was ridiculous to drive it around but I just couldn't resist.
Posted: Wed Jun 01, 2011 6:43 am
looks cool on the video. I would love to see the look on a cops face if you had to explain this one...
Posted: Mon Jun 13, 2011 11:26 pm
by sean
Spent the weekend sanding and spot filling the body for final preparation for the last coat of primer. I will be spraying it this coming weekend. Once that it is done I must start with the water sanding for preparation of the final coat which can hopefully be one within the next month.
Posted: Mon Jun 13, 2011 11:34 pm
by sean
This is more or less the colour I am looking for. It will probably be best to keep it an original fleetline colour but I do like the cream colour of those baywindow's quite a lot.
Will also spray it two tone but will follow the v-pattern on the nose, also I suppose not original but keen for it none the less.
Posted: Tue Jun 14, 2011 2:19 am
by fleetline15
The bays look like savanah beige to me nice color.
Here is as reference site for OG colors.
http://www.thesamba.com/vw/archives/inf ... stype2.php
Mitchell
Posted: Tue Jun 14, 2011 8:29 am
by jolas
Nice progress Sean. Is that photo of the Fleetline taken in Simons Town ?
Posted: Tue Jun 14, 2011 9:14 am
by fig
jolas wrote:Nice progress Sean. Is that photo of the Fleetline taken in Simons Town ?
I took that pic years ago. Yes, in Simonstown. I haven't seen that bus since. Is it still around?
Posted: Tue Jun 14, 2011 10:12 am
by jolas
I know it was sent overseas a few years ago ...........
Posted: Tue Jun 14, 2011 12:44 pm
by alants
Man you are way braver than me !
There is no way I would have even thought about this one
Hang in there - can't wait to see more progress
Posted: Sat Jun 18, 2011 8:45 pm
by Donovan D
Are you using the NS4 primer ?
Posted: Sat Jun 18, 2011 9:43 pm
by jolas
fig wrote:There's no difference between the front engine tin on a Beetle and a split bus. The tin is different between single and twin port (twin port has a cut-out for the oil cooler air outlet; you can cut a SP tin in need). The early type1 engined baywindow buses have a different front tin to the Beetle; it stands a bit higher. You can see how VW simply welded an extra bit on top.
I took this pic a few years ago when I was trying to get my 1970 Westy on the road, did'nt realize there were so many different types ....
The middle "tin" is the one Fig is referring to
Posted: Sat Jun 18, 2011 11:49 pm
by sean
Splitz wrote:Are you using the NS4 primer ?
Howzit Splitz
No, it's 2K MS primer.
