My 72 project'''with 6 inch narrow beam''
Phillip
Re: My 72 project'''with 6 inch narrow beam''
Post by Phillip »
Ok,so ive done a test fit today on the beam,this is with a rostyle 185/65/14.im going to fit std rims when everything is done,i got my tyres today,front std rims with 145/65/15,,,rear widened 185/65/15
This is set at the highest point on my adjusters
widened rear,,,ill sandblast and paint rims before tyres goes on,and then a nice set of white walls from callooker
Post by 1972 »
Looks great!!!! :hangloose: What drill bit did you use to re-dimple the torsion leafs?
Phillip
Post by Phillip »
thanx,ive used a concrete drill bit,works like a bomb.
splitfan
Has thanked: 46 times
Been thanked: 26 times
Post by splitfan »
Looking good there !Yep this beam building thing is a hit and miss at best the bodys of the busses (specialy) are not all the same they seem to "move" with age :? we had to "adjust" Donovans beam 7mm between the towers the beam was build on a jig that has seen at least 5 beams with no issues and the beam fits the jig 100% so i dont know :(
Phillip
Post by Phillip »
hey splitfan,sounds like uve done a couple of beams,hows a bus beam to a beetle beam,more work how much at the most can u narrow etc ?
splitfan
Post by splitfan »
Hi Phillip , a bus beam is "work" and cost more because i dont re use the shock towers i have new plates laser cut, but then again a 6inch beetle beam with custom mounts is also not a saturday afternoon job.I dont know how the "aftermarket" guys can sell you a narrowed beam and they all fit I prefer having the car or bus to take measurements from and building the beam from there.
Donovan D
Has thanked: 150 times
Been thanked: 73 times
Post by Donovan D »
That looks really great !!
:hangloose: :hangloose:
Hloni
Has thanked: 14 times
Post by Hloni »
Hey Phillip, is that steelie a tad wobbled on the inside (6-9 o'clock) from the weld?
Lekker to here that you were able to source the front skinny wheels. What are those commonly fitted on?
3011
Phillip
Post by Phillip »
Thanx splitz,,,,,hi hloni,no the rims r perfectly straight,theyre just very dirty.i got a set of smart car tyres for the front (145/65/14),now i battle to get reversable adaptors for the disc brakes :cry:
