Split bus adjustable Straight Axle Kits finally done
- MINCE
- Has thanked: 4 times
Re: Split bus Straight Axle Convrs Kit and Beetle adjustable
Yeah, I noticed
Ok another update
The first kit as you know by now is in a bus I am just finalizing everything that I can take the Bus to Wheel Alighnment to check the Alighnment then there is 2 small upgrade mods that needs to be made and then I can put the Kit on the Market AS I dont want to make it and it is not 100% correct
I will most probably make Handbrake cables for the Disc Kit that can accompany the Kits
Some Pics for you guys
- karmakoma
That are for 2 be like SAXY , very very Saxy.
Your kit, and a red 9 design front suspension, and any bus is ready for the urban jungle
- What model do you have?: 1971
- Facebook: yes
bugger stop buggering around i need my kit
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
Hey bud
Looks like you've been busy
I'd been quite keen. Let us know once you get some prices
Ok Will stop Buggering around Kevvy
thanks for showing interrest in the kit guys
It is close now to the Finishing line all I ask is a little bit more Patience
Re: Split bus Straight Axle Kit and Bug finaly enter product
Hi Guys
Update that I am happy with the Result of the first kit that was fitted to the red and white 15 window bus
As they are Adjustable one of the major advantages is that when you jack the back up the wheel rim comes down completely out of the fender well so changing tyres will be a breeze as I know of 2 fellow members that have a real struggle when they need to replace tyres
I have a dics kit on the 15 window and 30mm spacer bringing the wheel more out and you can even fit a wider spacer for a nice wide rim
and there is about another 3 finger gap between the outer of the rim and the inner of the fender
The pricing will be R3600 Incl your trade in of RGB`s with spring plates and R4500 exclude your RGB`s for both sides adjustable spring plates and 2 Boomerang spacer plates
The Axle tubes will be supplied modified to length for R2000
If you have both Axle tube sets (One set Early and one set late model ) the Labour to cut and extend and weld in the Jig will be R800
I will trade inn your RGB Boxes and tubes as you will not be using that anymore with your old spring plates
Ok can the Guys that is interrested pls contact me by PM and we can take the next step
This is a list of guys that mentioned interrest
Beetlefanatic
kts Customs
Splitbusaholic
Splits x 2 Quantity brings the price down
herbi123
75 Fleetline
Karmakoma
Klaus
The first 5 guys to order will get the spring plates for R3000
now that will be a bargain
Beetlefanatic
kts Customs
Splitbusaholic
herbi123
75 Fleetline
Karmakoma
Klaus
- Facebook: yes
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Bugger wrote:Ok can the Guys that is interrested pls contact me by PM and we can take the next step
Beetlefanatic
kts Customs
Splitbusaholic
herbi123
75 Fleetline
Karmakoma
Klaus
The first 5 guys to order will get the spring plates for R3000now that will be a bargain
That aint me...I had to go back through previous posts as I was a bit confused at this one.
Split from Natal is the man
Splitz are you interested in a upgrade on your system?Bugger wrote:Ok can the Guys that is interrested pls contact me by PM and we can take the next step
Beetlefanatic
kts Customs 1 x Set
Splitbusaholic
Split got the right one now![]()
herbi123
75 Fleetline
Karmakoma
Klaus
- What model do you have?: a few
- Been thanked: 4 times
hi Bugger
yes i would like one set as discussed previously
the cut out you did on the spring blade to lower the "wheel" , would it not be easier and safer to just cut that littlle head off .
what you say ?
what you say ?
Good you number 2herbie123 wrote:hi Bugger
what you say ?
Herb I dont think that little bit will cauze failure
it will not be a to big a job to grind that lip off but I thought most guys dont want to cut that away and the reason I integrated just that extra
At the end of the day that little cut out is not even nessesary as the wheel does go quite far down to still remove and replace the wheel
I have not given the final count to totals
If you want one with out the cut out then you guys need to tell me before Friday 21 Oct then the Plasma guy can do the amounts
Personally I will leave the cut out in the spring plate
thank you Pierre
Please make a set for me without the "cut outs"
Will discuss Plasma guys with you when i see you next , I use someone in Durban at half the price of the JHB guys , and still with getting it courierd up here
