Type 3 engine build
- Been thanked: 98 times
Re: Type 3 engine build
Crank is late 1600cc & flywheel is 12V any pics of the underside of the block?
Phone him on 028 840 2087 or 083 522 3109brianj wrote:Who is arno? Called volkspares and they dont have anything for a type 3......retrovan wrote:Go a nice 4-1 for the beetle, from Arno, looks like a beetle exhaust from outside, but sounds better.
- Single Port
- Has thanked: 13 times
have a very bad pic, but tell me what you see... the motor has definitely been built once before, but looks like it was a decent job - vw bearings, ks pistons .... what is the significance of the crank / flywheel?calooker wrote:Crank is late 1600cc & flywheel is 12V any pics of the underside of the block?
- Single Port
Going thru tomorrow to inspect all the parts and make a list of whats required, and take the parts that requires machining away to be done. Will post some pics of hopefully much cleaner parts.....
- Single Port
OK so a small spanner in the works.... I have sent the case to be machined and ordered the pistons and exhaust... BUT I managed to pick up a universal case longblock in running order(allegedly)... I am very tempted to build the new block up with my parts and install it to get the car going, then I can build the original motor at my leisure...
- Single Port
time for an update...
have been very busy and in my quest for rocker arms, came across Bill and his workshop. I asked if he would consider putting the motor back together for me. He has agreed and I have delivered all the parts to him now. Today I went to collect the tin for painting and he is about to close the block. some pictures attached by way of an update. Overall the motor was in good nick, and is now balanced and will hopefully sing like a sewing machine. Glad I have gone this route because no amount of following the book can compete with the tips and tricks learnt over many years.
So far have purchased:
empi exhaust - the old one was welded and tired
sachs clutch - probably wont use it, the old one was like new..
pistons and sleeves,main bearings, big and small ends, cam bearings, all valves, exhaust valve guides, oil pump, new oil strainer so far
- Single Port
OH dear... a stud has pulled when putting the case together....
brianj wrote:OH dear... a stud has pulled when putting the case together....
Type 3 blocks do love to do that
The engineering company should have checked that
I had all replaced with case savers for safety as this is a prone problem
- Single Port
one of those things... the case has been torqued by mcdonalds and when putting the bearings in...
O
Sorry I thought you were talking about the head studs
Strange that a casing stud has pulled
Mcd has done my casing and everything also and They checked all that for me
Uncle Bill has a strong hand
Was it a head stud or a case stud that pulled?
Sounds like a Case studcalooker wrote:Was it a head stud or a case stud that pulled?
- Single Port
case stud...
- Single Port
ok back on track. small delay from the pulled stud, but now everything is going smoothly. Tin is painted and back to Bill, he has now closed the block and heads are on. Happily no more stud issues. Just the oil breather to arrange and we should be up and running in a few days...
