Update time!
Firstly.............. Pierre, you are an absolute LEGEND! Thank you so much for all your help. Your workspace is a pleasure, your tools are the best, your knowledge is invaluable
I got to Pierre’s yesterday at 7:30 am. The drive there was a little hair-raising I must admit. I’d managed to get a little more out of the brakes by bleeding them again Friday night, but they were still far from safe.
We got the bus hauled up on Pierre’s bus hoist and stripped the brakes completely. One lining in the front right drum was totally detached from the brake shoe and the rear brake cylinders were leaking badly. We took all eight shoes and the four drums to a friend of Pierre’s who skimmed the drums and relined the shoes – flawless work and in record time!
Next I got cleaning all the crap off of all the bits and pieces with an ingenious paraffin trough device of Pierre’s - everything was shiny and new! We then honed the rear brake cylinders and started to re-assemble everything with brand new bearings and seals. While we were at it, we installed new axle boots as well and drained the RGBs and gearbox which we then later topped up with fresh oil.
I re-assembled the rear brake components while Pierre busied himself with the front lot and then the brake bleeding started – I can still barely walk after all the thrashing about on the brake pedal!
Next I slapped on the new rims and tires (thanks Dr. Watson) and finally, the hubcaps (thanks to Rui). We got the bus on the ground, tightened everything up and went for a spin. The results are fantastic! The bus stops in a perfectly straight line and is SO much more stable on the proper bus tires. The difference is truly incredible.
I’d mentioned to Pierre while we were working that I’d had a little trouble getting it to fire up from cold and the next minute, he was in the engine bay and fiddling about with the choke and carb. The bus now starts with a flick of the key and runs like it just came off the showroom floor.
The last thing we got onto was the nose badge! We made a template from another split which had the holes drilled and the badge off. Having fitted it, we’re both in agreement that it’s a little low but it’s exactly where the other busses was so I’m happy with it
I saw the bumpers that Pierre has kindly arranged to have sprayed so that’s going to be the next exciting instalment!
I had a camera with me but with a rather minute memory card so we only got a few pics. Here they are nonetheless:
