Fomula Vee Rebuild
- JamesD
- Been thanked: 20 times
Re: Fomula Vee Rebuild
Two brand spanking new slave cylinders into the rear type 3 drums on the front of the car. Yes, it runs type 3 rear drums on the front. and here is a pic for fun...
Interesting about the gearbox, will run it and then see whats allowed in historics before bugging Bugger...You do not have the required permissions to view the files attached to this post.
From fastest to slowest:
'75 SP 1600 with a few mods
- JamesD
Caterham style seat. Rear section in primer. all glass panels drilled and attached with Dzus fasteners.
we may have found a new easy way to put on a new "gel" coat to prevent surface cracks coming through while maintaining a thin panel. Might report back if it works...
- MarshallGTi
- Camshaft
- Has thanked: 7 times
- Been thanked: 11 times
DRUMS ON THE FRONT.....?
Ryan Marshall
- Ron&Gill
- Been thanked: 21 times
Sure, a light little car like that, heat easily dissipated through aluminium drums, low unsprung weight, why not?
- JamesD
one word - Regulations!
- Ron&Gill
JamesD69 wrote:one word - Regulations!
- MarshallGTi
- Camshaft
and a supply of adult diapers just in case......
Ryan Marshall
- JamesD
Not needed and wont fit in the new seat either anyway. Just swop out the brake fluid for Motul RBF 600 and you sorted. If i haven't managed to boil RBF 600 in either my Elise or the Birkin then it will come no where near boiling in the Vee. And correctly adjusted drums are just fine for 10 lap sprint races or a hill climb.
- JamesD
Well i took it for a drive. this thing is going to be a handful to race, It is bloody fast for what it is. Now i know why they limited them to 1300's! Can pull off in 3rd like you pull off in first in a beetle. Need to drop the front suspension and work on the rear suspension a bit.
- JamesD
Lets play a game of spot whats new! Besides my 2l coke bottle fuel tank
There is more than one new thing added....
- dubster
- Been thanked: 3 times
tail light?
1974 1300tp type 1
kart kraft 1717cc buggy
- JamesD
Yip, 1 point for you good sir, wanna try for more?
- MarshallGTi
- Camshaft
paint on the engine cover and new axle boots?
Ryan Marshall
- JamesD
We not happy with the paint on it, it's gonna get resprayed. And the boots are old news.
The new bits are the rocker arms on the rear suspension. the old ones were horrible. the centre bush had siezed and the whole unit had broken out of the rocker arm. bit of dremel work and i had all that removed while my father set to work knocking up the rocker arms.
Proabably spray the rocker arms yellow to match the other yellow bits on the car. Gearbox needs to be painted some colour, need to go look at the hammerite selection available, or might use an engine enamal grey.
new oil cooler scoop made up out of alli aswell (not pictured). we relocating the oil cooler further forward than what it used to be, almost down next to the driver.
And i feel A LOT safer with the caterham style seat in the car and a lot more comfortable.
- triton
- What model do you have?: Formula Vee
so when do I get my car back. LOL I'm so jealous. Looks so much better. Fantastic job
"Shit happens"
