My 76 Type 1 13BT install
Re: My 76 Type 1 13BT install
Just came in now after re installing the motor from before fitting the new Copper Clutch and pressure plate back in to the Bug
Should get it started during tomorrow and finalize the front rubber scoop and get it back at the Dyno
and back to Mathew so he can enjoy his bug
- Qkickslvr
- What model do you have?: Type 1 1976
Great news Pierre! Let me know how it pulls!!! Interested to know what it does on the dyno.
I'll bet you the car is running perfectly but Pierre doesnt want to give it to you just yet
- Qkickslvr
awesome... anxious times...
Well there is definitely one or 2 of the injectors that is Faulty as the over fueling from the Injectors has caused Damaged to a R1200 set of Brand new Plugs
Ad that was Part of the Fualt finding prosses but Fitted a Temporary Alternative set of Plugs and the Bug starts Up to Live now
Best is to have it Dyno`d and then Mathew can Enjoy his Bug as the cooling is good but one of the common problems on the Rotaries is when they stood for a while at the importers is the Water pump seals goe very hard and then the shaft start leaking slight water out of the small hole that waterpumps have to indicate Problem
- Qkickslvr
Nice and low.
- beetlefanatic
- Has thanked: 8 times
- Been thanked: 12 times
Well done guys. It looks great.
I wonder how my cab would look next to that bug.
- Qkickslvr
upload a pic of your bug so we can see.beetlefanatic wrote:Well done guys. It looks great.
- Qkickslvr
Bug is going either today or tomorrow for the dyno. Unfortunately I'm not able to be there would have loved it!!! Never the less will have the bug back this weekend. Can't wait!!
keep us posted on what happens!!!
