Squarback newbie's Square-stickered up..almost complete
Squareback newbie
What model do you have?: 1967 Squareback
Re: Squarback newbie's Square-new pics added
Post by Squareback newbie »
Car now lowered.....all body panels arriving tomorrw
before and after
MrT
Has thanked: 22 times
Been thanked: 9 times
Post by MrT »
Squareback newbie wrote:Car now lowered.....all body panels arriving tomorrw
before and after
That's Low! What size tyres are you going for? My car has 195/70's and they touch the body on wild humps!
Re: Squarback newbie's Square-car now lowered
Yo That is low are you not afraid you will not be able to travel some of the Hump Roads in and around Jo-Burg :lol:
You have the car this low, but still need to fit all the hardware, Normally, one waits to lower the car when complete, as you still have to add a lot of weight allover the car.
All the best.
Been thanked: 21 times
Post by Ron&Gill »
There's more to lowering a car than letting down the tyres, isn't there? :lol:
Squareback newbie
before and after
LOLO yeah wanna get it as low as possible.. low and slow...
rears i have 185-65-15....and fronts i still haveta get.. but between a 145-65-15 and a 165-60-15, decision will be made on the cheaper of the 2 tyres lololol..if i cannot get those tyres.. gonna go with a 175-50 15......
When u lower it more the rears have alot of negative camber.. so the already inside my wheel well with not touch... still haveta put on all the panels.... so if its to low, ill raise it 1 spline at the back...., assembly starting already..
Squareback newbie
Bugger wrote:Yo That is low are you not afraid you will not be able to travel some of the Hump Roads in and around Jo-Burg :lol:
hehhe yeah im afraid.. wanted to really get it to "sit frame", so this was the next step lololol... i hope to keep it this low, but if not ill be forced to raise the back 1 spline which i dont really wanna do...:(
Squareback newbie
retrovan wrote:You have the car this low, but still need to fit all the hardware, Normally, one waits to lower the car when complete, as you still have to add a lot of weight allover the car.
All the best.
:twisted: mm i likes the sound of that :) the lower the better :hangloose: , seriously, will check when all panels r on... wanna get it as low and well should i sayundrivable as possible..lololol..., the pan im using is rusty and full of holes, so if its damaged im not to bothered with it as im restoring my other pan, this will be more of a trial to c how low i can get it and driving the smoothest rodes i can heheh, which is probably to garagae and back only
I will upload more pics when the panels r fitted i hope to have them fitted tomorrow morning/afternoon.
Thanks for the heads up, ill def check and recheck when all the panels r back on
Squareback newbie
Ron&Gill wrote:There's more to lowering a car than letting down the tyres, isn't there? :lol:
:hangloose: heheh yip.. the cement bags worked for a while heheheh.
if u a hands on person its not such a big job, after lowering the front \ 3 times to get it to sit kinda even with the back, the 3rd time both fronts took my son and i 30 min, to lower and put tyres etc back on,,,, rears took a bit longer, about 2 hours,(should be a bit quicker the second time around),...will keep it updated... cars beig polished at themoment....
Neuk
What model do you have?: A few...
Post by Neuk »
Progress looks great, quite low though, how many splines did you drop it back and front?
Nic
Current:
Daily Drive: 2005 Audi B6 A4 Avant
Project Fes: 1982 VW Golf GLS
Project FeO: 1966 VW Type 2 Kombi
Project XXXX: 1967 VW Type 3 Variant
Previous:
Project Betty: 2005 VW Polo Sportline
Weekend Warrior: 1993 VW Caddy 2.0 16v ABF on ITB's
YvaneS
What model do you have?: :)
Has thanked: 11 times
Post by YvaneS »
Lololol
Squareback newbie
Neuk wrote:Progress looks great, quite low though, how many splines did you drop it back and front?
Howsit Neuk, front we went 4 or 5 on the inner spline, on the rears i counted 3 splines on the inner spline, but then it was slammed like this, i rechecked this twice....... wheels arrived (broadened a bit) will have it panited next week and ftted..probably the w/e..... car assemebled.... just haveta align some of the gaps now etc... should be almost complete next w/e.......crossing my fngers i dont have any issues popping up now, need to have it sorted for camp fest
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
I used to roll in a fasty that was lowered two splines. eventually I had to modify the lower beam mounts as they were scraping when hitting undulations in the road. The car was about 10cm of the ground at the beam.
What you are doing here is putting your and passengers lives at risk. When a type 3 is lowered more than 2 splines you are running out of travel in the ball joints and this binding could cause them to break
This is the reason that seriously lowered cars all over the world run king and linkpin front ends as this binding is not present.
Regards
Has thanked: 36 times
Been thanked: 50 times
Post by flatfourfan »
Holy rocking horse poo..............good luck with your first day driving it.
First pot hole or speed bump and you going to leave your spare wheel well behind.
