Project Frankenweenie
Riekert
Camshaft
Has thanked: 111 times
Been thanked: 23 times
Re: New project Beetle...
Post by Riekert »
Ron&Gill wrote:O, you're in Sandbaai... Gill's aunt lives in Sandbaai.
Yeah. Work in hermanus and live in sandbaai :D
Riekert
Camshaft
Post by Riekert »
Hey guys. Need some help... How can I rewire a 12v alternator setup to work with a 12v generator?
Riekert
Camshaft
Post by Riekert »
Oh also any help IDing this motor? Image
Any help will be awesome. Evetything I can dig up is that its a 1600. But got conflicting info saying its a 1200:???:
thats not a 1200
look for info on the AD letters. SF is a South African letter stamp (rebuilt I think)
Riekert
Camshaft
Post by Riekert »
Thanx tony. Most of the info I get on the AD number tells me its a 1600. But the guy who I bought it from said it was a 1200/1300. So really confused :|
This is what I got from the samba :
"Type 2 engine
AD 1971-73 1600cc 50bhp DIN. Non-USA."
So it should technically be a 1600 bus engine?
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
Riekert wrote:Hey guys. Need some help... How can I rewire a 12v alternator setup to work with a 12v generator?
do you want to convert from a 12v generator to a 12v alternator????
Riekert
Camshaft
Post by Riekert »
Nope other way around. Seeing as the beetle is wired for a alternator and I've now put a engine in that has a 12v generator
MarshallGTi
Camshaft
Has thanked: 7 times
Post by MarshallGTi »
just the wiring on the regulator needs changing i think.
AD is a 1600 beetle motor same as mine.
Ryan Marshall
3250
get an alternator. More money you say now, but they are also much more reliable
Riekert
Camshaft
Post by Riekert »
Thanx guys! Sweet deal on the 1600 :D hehe. I've got a 1600 twin port that I can rebuild too so yay!
And Thanx will get a alternator then
Riekert
Camshaft
Post by Riekert »
Swapped the notches rostyles for the beetles now the beetle can almost go for roadworthy. Just need to sort engine and brakes.
Riekert
Camshaft
Post by Riekert »
So the flywheel nut came loose on the beetle. how that happened I dont know.
Anyhow. Got it back on and sorted. But struggling my ass off to get the motor back... Sigh...
Anyhow... Some pics.
a stock weight engine is easy to get in and out.
1x trolley jack and 4 bricks is all you need.
Drag engine under car into engine bay.
Lift one side by holding onto cylinder head cover
put brick under exhaust.
lift other side, put brick under.
repeat until engine is 2 bricks off ground.
put jack under engine, lift and install.
Now the question... did you put that flywheel back onto that crank?
Flywheel is fkd
crank is fkd - look at the ridges around the dowels (I am not even mentioning the state of the dowel holes).
did you set endfloat properly?
The flywheel probably wasnt torqued down properly in the first place.
Riekert
Camshaft
Post by Riekert »
Thanx
New flywheel old crank... :sad:
Would it be at all possible to redrill the crank?
Otherwise I'm fooked :(
Endfloat still seems fine
Has thanked: 425 times
Been thanked: 543 times
Sorry to say, thats a full engine rebuild, that crank will have to be welded and re-drilled at best
And it will have to come out to do that.
Else you f%$k-up the rest of the engine.
