EL Puma project.
oldschool75
What model do you have?: Kombi Keg
Has thanked: 20 times
Been thanked: 9 times
Re: EL Puma project.
Post by oldschool75 »
Mr_Cassidy wrote:Why not go with Type 4 power like I did. I'm busy modding it to take an injection system off 2.1 wasserboxer motor. I've already done the electronic ignition system using a TP900 and a golf wiring loom with the distributor from the 2.1 it works like magic.
You get good reliable power and you keep the car true ACVW - It's pretty much just a bolt on conversion.
Check this out :
http://members.rennlist.com/pbanders/dj ... htm#setups.
It runs cool as the venting is sufficient as well.
I think the dual trumpets are a nice touch as well.
Just my 2c.
Regards,
Cass.
Cool backlights, how did you do those?
There's a rally driver hiding in all of us......
Kombi Keg - 1976 Panel Van
Miemie - 1967 Type 3 Fastback
1982 unique Buggy
VW-rules
What model do you have?: 1961 Bus
Has thanked: 10 times
Belgium
Post by VW-rules »
So I've had a bit of time to start re assembling and I've hit my next snag.
The window winder mechanism which came with my Puma are rusted beyond recognition.
Are there any wise old wizards out there who know the origins of this part?
Has thanked: 45 times
Been thanked: 208 times
Reminds of the 56-63 beetle window regulator. There are differences, but could probably be modified to work.Image
IMPI
What model do you have?: sp2
Been thanked: 78 times
Post by IMPI »
Same part as pr 65 vw exept for winder attachment needs a hole drilled and tapped been there done that
VW-rules
Belgium
Post by VW-rules »
Thank you o'wise ones :bowdown:
