Thank you Terry
My DIY farm buggy
- What model do you have?: 1600 off-road thing
- Has thanked: 34 times
- Been thanked: 5 times
Re: My DIY farm buggy
- Donovan D
- Has thanked: 148 times
- Been thanked: 73 times
Well done, looks as if a lot of time was spent building the buggy.
Hi Bugger,Bugger wrote: Mon Jul 29, 2019 8:25 am Been Following your posts on 4x4 Action Group aswell
nice to see the light at the end of the Tunnel
What type of gearbox oil would you recommend?
Took of the cylinder heads, cleaned the heads and valves, replaced the push rod tubes, adjusted the valve clearance.
Painted the shroud, generator, intake and exhaust, replaced the belt, distributor and fitted the new carburetor.
New spark plugs, adjusted the timing.
Still not idling as it should, but I will tweak the carb to get it right.
A video of it running - and me revving the nuts of it (I could not help myself):
https://www.youtube.com/watch?v=Ht5n0pQYNfI
You can hear in the end the kids love it too.
Nice well done.
- Has thanked: 193 times
- Been thanked: 121 times
Nice job thats what you do on your toy I would love to see what your other toys look like.Well done something to be proud of.
Thank you.Terry Phillips wrote: Tue Aug 27, 2019 2:37 pm Nice job thats what you do on your toy I would love to see what your other toys look like.Well done something to be proud of.![]()
Auto Zone sell a Castrol 80/90 gear oil that is goodRicoffy wrote:Hi Bugger,Bugger wrote: Mon Jul 29, 2019 8:25 am Been Following your posts on 4x4 Action Group aswell
To do List:
Re-install seats and side steps;
Adjust and bleed brakes (and handbrake)
Wiring and dashboard assembly
Re-fill gearbox (have to do this after I replaced the axle boots and rear hub seals)
drop in load-bin (wood)
- Camshaft
- Been thanked: 107 times
It's too pretty for the veld now !!!!!!,.....you'gn want to clean it everytime you come back?
Good job!!
Good job!!
Far to good to have a pig in the back...
Nice going
Nice going
