Oil leak form crank pulley
- What model do you have?: Love Bug
- Location: Nazereth, Ethiopia But Stuck in Los Angeles at the moment....
I know. Sounds strange. But I have the report from VWoA. I will post it when I get back to Ethiopia. Most engine builders in the USA have seen this same report. Just ask them.
But, just think about it. if they were just trying to take care of the oil leak problem. Why go to such a complicated methode of stopping the oil from leaking? Could have just put in a standard seal and been done with it.. Just one part instead of the oil slinger and specal coring in the crank case and all the required machining on the pulley and case. The seal there would have even been really easy to change.....
- forcecooled
- Single Port
- Been thanked: 5 times
Rift
While I do agree with you on what you are saying (mostly) I dont think you have it 100% correct when it comes to the scroll on the pulley and its function.
If you look at the scroll especially its depth and then check on the amount of clearance you have between the scroll and the case, it would make for a very very poor air pump. Any air that enters the scroll will just be slung out under centrifugal force against the case, causing only turbulance and not actually doing any pumping...
What is the use of this???
Ever heard of a labyrinth gland? Its a sealing arrangement used on turbo chargers, steam and gas turbines and other high speed machinery that doesnt need to stop a high pressure flowing, but rather stop a low pressure gas from passing it. The labyrinth gland does this by making a highly difficult route for any gas to flow through.... just like the scroll on the vw crank pulley.
While yes, you will prob find that a little air does enter the case, the scroll is primarily a seal and not a pump.
No the crank doesnt bathe in the oil.forcecooled wrote:Now the crank touches the oil in the sump.
Now the dry sump pump creates negative vacumn in the case
Now the main seal operates under the full pressure
of the spillover oil from the bearing
KAK!
A negative vacuum is actually pressure. You either have pressure or a (partial) vacuum. The scavenge pump in the dry sump pump is used to suck oil from the crank case... this is bigger than the pump used to pump the oil into the case to ensure that oil doesnt build up in the case. This does assist in removing gasses from the case and may produce a partial vacuum if the case is sealed and the blowby isnt much.
what is it and when do I get it????Riftvalleyvw wrote: About the crank. The crank is not under the oil, but it is touching the oil. This is the reason why there are so many dry sump applications for American cars. It is probably more common that you think too. Most air compressors and refrigerant compressors use only splash oiling as it is called for lubrication. I have a 350 Chevy on a stand right now. When the rain stops I will take a photo and send it to you. If you are right I will send you something for your motor!
You've lost me.... PCV???
Positive Crankcase Ventilation System. An early form of emission control. All cars have it, even today.
The Idea was to suck the blow by, oil mist and the gasoline that leaked out of the carbs while the motor sat out of the case, suck it back into the carb and reburn it. Trying to keep it out of the air.
- forcecooled
- Single Port
I just did a quick search of the web and found these sites. ONe by a very respected VW guru.
http://www.vw-resource.com/crankcase_ventilation.html
http://bobhooversblog.blogspot.com/2007 ... ating.html
Bob hoover has a lot of interesting photos and diagrams for all you aspiring VW mechaincs. It is a very good read. You will need to look for the section on Crankcase ventilation.
