Page 3 of 21
Re: 61 Westy
Posted: Mon May 26, 2008 7:52 am
by flatfourfan
Oi vey......................
Re: 61 Westy
Posted: Tue Jun 10, 2008 9:58 pm
by lowlight
Engine back in. 12v Starter need overhaul, and is out again. Hoe meer haas hoe minder die spoed.
Re: 61 Westy
Posted: Tue Jun 10, 2008 10:04 pm
by Chris
Glad to hear you are making progress
Re: 61 Westy
Posted: Thu Jun 12, 2008 3:02 pm
by lowlight
starter is gone ..... need another.
Re: 61 Westy
Posted: Sun Jun 15, 2008 10:45 pm
by lowlight
Got one. Starter is in and turning.
Re: 61 Westy
Posted: Mon Jun 16, 2008 9:43 pm
by lowlight
Fuel pump not working. Replaced. Battery need replacing
Re: 61 Westy
Posted: Sat Jun 21, 2008 11:28 pm
by lowlight
Got a bend pushrod and stuck valve :evil: :cry: Still no battery. Started working on the engine lid, take out some minor dings and sand the rust and treat it. Will put primer when back from Pta.
Re: 61 Westy
Posted: Sun Jun 22, 2008 9:52 am
LOL.... how many more things do you think can go wrong???
keep the updates coming
Re: 61 Westy
Posted: Sun Jun 22, 2008 3:35 pm
by didi
It looks like the Westy is throwing it's best at you. I know it can feel frustrating, but just keep on going. Spend the time and sort it out one by one. It's worth it. :D
By the time youre done you will have bonded with that car!
Re: 61 Westy
Posted: Sun Jun 22, 2008 10:40 pm
by Dirk
And be in a position that you'll be able to fix anything that can go wrong with it. That alone is worth every second of pain. :)
Re: 61 Westy
Posted: Thu Jul 03, 2008 11:30 pm
by lowlight
Thanks for all the moral support.
Progress?
Bought new battery. Still no fun. Then went through the everyting, plug wires 1and 2 was swopped, :oops: fix that and the motor start, but need to pump it to keep it running. Problem with carb, Cleaned it and put it back, wil see over the weekend if it will idle now.
Next willbe the exhaust.
Re: 61 Westy
Posted: Thu Jul 03, 2008 11:33 pm
check for vaccuum leaks.... spray quick start all over the rubbers and listen for a sound chance, if you have a leak, the quickstart will get sucked in and the idle speed will increase.
Re: 61 Westy
Posted: Thu Jul 03, 2008 11:36 pm
by lowlight
Thanks will do
Re: 61 Westy
Posted: Mon Jul 07, 2008 9:10 am
by lowlight
Starter sorted. play on the bush. Carb out busy to clean it and will then put it back. Problem with idling? Could nt swop carb cause this is 34 and I only got smaller 31 and 28.
Re: 61 Westy
Posted: Tue Jul 15, 2008 11:32 pm
by lowlight
Problem on carb solved, its idling. :D
