Page 28 of 37
Posted: Tue Feb 02, 2021 10:51 pm
With the fuel tank in place I can start on the load deck
Also have the refueling flap fitted .........
No not for petrol but for battery charging or power take off ...... :lol:
Also have the air pressure tank fitted in place ....
And busy with the carb linkages.....
Posted: Wed Feb 03, 2021 7:00 am
by Donovan D
Condolences to you and your family.
Posted: Wed Feb 03, 2021 8:00 am
by Haans
Herman,...maybe it's. Too early to think for me but,......with Stoffel now being front wheel drive,.....should you not go for a bit of toe-out. .??
Posted: Wed Feb 03, 2021 9:44 am
Haans wrote: Wed Feb 03, 2021 8:00 am .....with Stoffel now being front wheel drive,.....should you not go for a bit of toe-out. .??Haans
When you right ,you right,
The above settings are for all our Aircooled guys with RWD,
and yes the MeFusco will have Toe-out of 3mm max.only because its FWD
Posted: Wed Feb 03, 2021 9:21 pm
by german
Also shouldnt it be standing on its wheels instead of hanging?
Posted: Wed Feb 03, 2021 10:09 pm
german wrote: Wed Feb 03, 2021 9:21 pm Also shouldnt it be standing on its wheels instead of hanging?
Should make no difference but yes the final set will be with all 4 wheels on the ground with all std added weight.
ie;- Fuel, upholstery, glass, carpets, air lift equipment, seats, back deck, re-painted undercarriage. and all.
As we were working on the carb linkages today, we noticed the accelerator peddle is still missing the peddle roller and shaft.
We where sure we had it some where, but its lost to future clean up
So now we will have to manufacture the parts before the cable can go in.
Posted: Sat Feb 06, 2021 5:38 pm
So today we spent getting all the parts together to do the much anticipated deed.......... :shock:
Whats that you ask.... :roll:
Well we tried to set every thing up by hand, carbs, timing, electrical and fuel, and now is the time to turn the Key.... :D
If you can not see it, try ... https://youtu.be/4ov0aGxOwTI
Well as you can see it was a great surprise when he fired up,
a quick check to see if we had all the requirements such as oil pressure, alternator charging, rev-counter working, and voltage gauge reading
all the time ready to switch off ......but... all went well, all was working and we could let him run a bit.
Yes he is running a bit ruff but still needs timing set, as well as carbs tuned, these where only set on the bench.
Must say Me,very happy with My self, and now I am off to pour us each a BELL'S
cheers!!!
Posted: Sat Feb 06, 2021 6:32 pm
by Dawie
Nice!!
Now indeed it's time for that Bells for each of you and yourself. All to be enjoyed by the same singular part of your personality. Enjoy!
Posted: Sat Feb 06, 2021 7:05 pm
by Terry Phillips
Well done Herman now you can sleep a bit better.
Posted: Sat Feb 06, 2021 10:17 pm
Good show!
Posted: Sun Feb 07, 2021 9:57 am
by Herbie
Lekker man lekker!
Posted: Mon Feb 08, 2021 8:37 am
by Haans
Jolly good show old chap!!!!!!!!! Don't all (me;myself&I) of you love it when a plan comes together !!!
A few more bells would not be inappropriate 😉😉😉😉
Be proud of yourselves
Posted: Mon Feb 08, 2021 9:38 am
Thanks Guys, yes it was a great milestone to reach.
Not much more to add to the weekly report, other then we fitted an 2nd earth strap between engine and body.
Also set headlights and fitted cover rings,
Will be making a longer clutch peddle cable cam, as this one is too short and will not give me full clutch release with full peddle movement.
Did a bit more air suspension air lines and fitted an external top up valve.
Well thanks for looking and till next update, keep safe
Posted: Sun Feb 14, 2021 8:54 pm
Sunday night and all is well....
Started on the wood for the deck at the back,
Had to trim me some planks and get them to fit.
Landed up with a workshop full of saw dust and the deck fitting well.
Now I need to cut and coat the metal strips to hold the wood down.
Need to clean the workshop before doing any more work, but have an export plant to build before that can happen, so.....
Keep safe and until next time.
Posted: Sun Feb 21, 2021 9:18 pm
Still busy with salt-mine, but did do some work on MeFusco.
Much against my own decision, I went ahead and had Armourplate make me two new side windows.
The old ones with the scratched where just to far gone to keep.
Striped the two doors down again to get the old glass out and the new glass back in.
Now doors are done but for the door panels, which will be fitted once the truck comes back from upholstery, when ever that will be.
Till then
