Page 28 of 39
Re: 14 year old build
Posted: Sun Jun 21, 2009 5:39 pm
by Pine
DUUUUUUUDE.... throw in some punctuation, please!?
I'm getting outta breath just READING it...
Posted: Sun Jun 21, 2009 5:48 pm
by 1972
Sorry Pine
That better?
Posted: Sun Jun 21, 2009 5:54 pm
by 1972
Picture 1:Marked stainless for cut
Picture 2:Cuting the sections needed
Picture 3:All cut
picture 4:cleaning up edges
Posted: Mon Jun 22, 2009 2:10 pm
by 1972
So today body roller build continued, here some more pics.Unfortunatly metal didnt arrive today but got a call from them saying, it will be ready tommorow.
Picture 1: had some slip pipe that will be used to allow the body to sit at different heights
Picture 2: cut bigger slip pipe to 30cm long and the smaller one to 32cm long
Picture 3: So that the body once ontop of the roller doesnt get damaged lying on metal found a piece of roofing beam. and cut it to 1.35 metres.
Posted: Mon Jun 22, 2009 2:21 pm
by Dirk
You really are motoring along aren't you
Posted: Mon Jun 22, 2009 2:49 pm
by 1972
Thanks Dirk
Have to move quick coz car has to be on trailer by friday,so the sooner i can build the roller the sooner i can get the body on it, and then its just loading it on the trailer
Posted: Mon Jun 22, 2009 7:11 pm
by 1972
So just finnished drilling the holes to mount the castors ,tommorow will be spent welding and doing the final touch ups lets hope it all goes well.
Posted: Tue Jun 23, 2009 5:14 pm
by 1972
OK so since im learning as i go along i need some help please.
I have a 1300 twinport engine that i want to have bored out to a 1600 so here is where i need the help.
1. What would it cost to bore the enigne to a 1600?
2. I want a mild street engine is a 1600 the rite way to go?
3. i already prosume i have to change the heads and all that what else has to be done?
Posted: Tue Jun 23, 2009 6:59 pm
by dubster
You have to open up the case to fit the 1600 pistons and sleeves if it has 10mm studs then get 8mm because they stretch beter heads have to be opened up or if you can get 1600 tp heads...id say if you could rather pick up a complete 1600 motor or long block it would save you alot of trouble just keep an eye on the junkmail ads...
by dubster
Posted: Tue Jun 23, 2009 7:23 pm
by 1972
thanks dubster ok you are going to have to help me out here
1. where can i get pistons and sleeves from?
2. what are studs?
3. if i find a set of 1600 tp heads do i still use the 8mm studs if it has 10mm studs
4. how do i know what size the studs are?
.........thanks
Posted: Tue Jun 23, 2009 10:15 pm
by dubster
you can look for good sleeves and pistons you should be able to get new from a normal spares shop maybe even sleeves but i doubt it,then there is importing but thats money and then you might aswell save some more and import a big bore kit...the studs are the things that hold the sleeves in place and bolt the heads to the sleeves...you can measure them with a vernier (dont know i that spelt right?) if not mistaken vw changed the studs when the 1600 came out or just before dont exactly know but 8mmshoul fit
Posted: Tue Jun 23, 2009 10:23 pm
by dubster
Its the case that has to be modified to to take 8mm studs and thats a slep and money...i really think you shoud look for a complete 1600, i think i saw one for 1900 (might be vrot,but you never know)in bf's junkmail ads,its in the end gonna be cheaper than a the engineering and stuff...or you could just fix up the 1300 for the time being,play with it learn how it works, and drive it like that till you find a good donor 1600...i dont think a 1600 beetle is that much faster than 1300 so you're missing anythin
Posted: Tue Jun 23, 2009 10:28 pm
by 1972
My plan was to rebuild the engine myself, (could be a desaster) but will be a learning process then if all fails will have one built up will see hopefully tommorow engine will be out then can have a look at it and see what has to happen from there on
Posted: Wed Jun 24, 2009 8:04 am
by dubster
Dont worry its not that hard to put together a motor...just work super clean,mark things the way they come off and torque al the thinigs that need torqueing correctly....
