New Project for the new year by new member :)
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Re: New Project for the new year by new member :)
Ok, got the Type 4 1700 motor today still need to check it out. This will be to do the mockups untill I get the proper motor buid. Will take pics 2morrow and post up.
Rgrds
Rgrds
What other people think of you is none of your damn business
- sarel.wagner
- Pushrod
TIV pic:
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Motor progress (Edit) Both are NA, nod turbo or blowers employed.
The infamous (in SA) Mr Raby dyno run (Compensated to sea level):
154.1Hp (115Kw) & 165.6lbf/ft (224.5N/m) My Simulation (at sea level):
170.3Hp (127Kw) & 197lbf/ft (267Nm) Very close between the two engines. Almost the same configuration as well. My graphs is from my design efforts and is only a simulation. That was the idea from day one, virtually build the motor, and then optimise the components, Intake size and length, Cam duration & lift, Valve sizes and exhaust. I am now happy with the results and after a lot of consultations with the local engine builder, he is happy as well
I still need to build all this (uhmm he has to), inluding a scratch build exhaust (that will be me, see the picture for one idea) (Tri-Y) 4-2-1 with muffler. Fun I know, to make and make it fit underneath at the lenght of 1.5m excluding the silencer. Each primary at about 0.5m and the secondary the sme, then the collector at more than 0.5m Rgrds
- sarel.wagner
- Pushrod
Eventually had a few minutes to update my blog, the final design for Impi to build. The numbers are there, 1400m high drops a LOT of power, see the graphs and numbers -> http://konzeptdrei.blogspot.com/
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Been awfully quiet in here work keeping me on the run. Also been doing a top end replacement on my Land Rover Defender after 300 000km. Started up past Sunday and all is well again. A few things to complete and tidy up, then back to this project. Not been doing nutting on it tho Web Camshaft and lifters on their way, got the crank and need to have that counterweighed and stretched to 80mm.
Got a few other bits n pieces as well like the barrels to be bored to 96mm etc.
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Have a look see here: http://konzeptdrei.blogspot.com/search? ... -results=5Farhaad wrote:wats being done to the body
More picture if you click the link.
Rgrds
Holy moly dont let Mince see this We`ll be in trouble
- MINCE
- Has thanked: 4 times
WHAT THE FU i am kidding
you are doing a custom job. it is okay
- sarel.wagner
- Pushrod
Its OK whatever I do, my money my project. Done some more buying, Web camshaft, lifters and some valvetrain spacers, all for the Type 4. Also got some camshft gears and an extra case with crankshaft to be stroked to 80mm. The Jugs are 2 liter to be bored to 96mm for the Keith Black slugs.
Rgrds
Rgrds
With that engine, I definitely want a spin when done!! Will be talking to you quite soon need to have my watercooled engine build modelled on your dyno software
MINCE wrote:WHAT THE FU i am kidding
Hey Mince Just Yanking your chain Think You had enough Abuse from the others I whish I had the Patience to do a Resto the way you are doing yours
My hat of to you mate keep it up
- sarel.wagner
- Pushrod
The new year started, a looong time ago.... Got the 2.0L engine stuff sorted, IMPI will start assembling soon , Bugger your turn to start the box soon mate wil let ya know. Also the Spitronix FI to power this lot must now be ordered.
Updated the blog, front brakes and Spindle, see the 73 spindle compared to the 67 one here: http://www.flickr.com/photos/sarel_wagner/6699496423/
and here: http://konzeptdrei.blogspot.com/
linked with linkr
linked with linkr
- sarel.wagner
- Pushrod
A new update on the blog, this time the gearbox, wheel size and the performance with the 2.3L motor.
http://konzeptdrei.blogspot.com/2012/01/bugdate-7.html
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Prepping the worm drive setup for the rotiserie. Enlarging the gear to weld to the pipe, kinda crucial to the rotation of the rotiserie
More on Flickr... Click image.
Rgrds
Rgrds
