Page 4 of 12
Question about engine tinware
Posted: Sat Jan 17, 2009 7:17 pm
by Barry
So on the subject of cooling again - some help/advice please.
This is what the engine bay looks like:
I plan on making up the tinware to seperate top & bottom in the area outlined in blue. What has to happen in the area outlined in red (if anything)? As well as the holes marked with crosses.
Is there tinware missing in this area? The rubber skirt would seem to indicate that there should be there, but besides some manifold heat, I would imagine most of the fresh air would be entering here - if anything I would like to increase this, with some positive force feeding by means of scoops under the car.
Re: The Volks Rodster
Posted: Sat Jan 17, 2009 7:24 pm
by Barry
Also, anything missing from the underside? - looks like there may be sonmething that should attach to the blue plate?
Anyway, not too much else to show. Bootlid is nearly done, and I've been fixing my screw ups on the sides - symmetry was a little off. Hopefully I'll have pics soon.
Thanks for looking
Barry
Posted: Sat Jan 17, 2009 7:25 pm
by Chris
What about a scoop,like you said,under the car that feeds cool air rirect to the fan.
Those holes can be blanked off,because that is where the pipes that came from the fan shroud went through.
Posted: Sat Jan 17, 2009 7:27 pm
by Chris
Is the "forget-me-not" plates on the bottom there?
Posted: Sat Jan 17, 2009 8:32 pm
by gazzapen
I Also wondered about the scoup idea but canned it after checking how the air actually flows when cooling a beetle engine.
Air is forced from the fan housing through the sleeves and the oil cooler out the bottom of the engine. The air is therefore hot when it omes out.
Air flowing at the bottom of the engine ensures that this air is dispersed away from the engine. It also flows over the bottom half of the engine (that is ribbed) and cools down the block and sump.
I figure that putting a scoup would remove this airflow and could be counter productive to cooling.
I think It would be better if you make vents on the hatch allowing air into the engine compartment.
Posted: Sat Jan 17, 2009 8:51 pm
by eben
Dont know if this might be useful to you:
Posted: Sun Jan 18, 2009 6:10 am
by Barry
Thanks Eben - that's useful.
I think I'll need to check out standard set up - don't know about the "forget me nots"
Barry
Posted: Sun Jan 18, 2009 9:53 pm
by buggyfan
Barry wrote:Also, anything missing from the underside? - looks like there may be sonmething that should attach to the blue plate?
Thanks for looking
Barry
1 on photo is forget me not plate
2 gets attached to original exhaust with heaterboxes.
Posted: Sun Jan 18, 2009 10:15 pm
by Spex Dallas
Looks like a cool ride you´re building, keep up the good work.
Posted: Tue Feb 10, 2009 9:54 am
by Harry Jones
Hi there Barry ...
Any updates ....? pics ....? all going well ....?
Posted: Tue Feb 10, 2009 10:03 am
by Ron&Gill
Did you get all the answers? Like at the back of the engine, there's more Beetle tinware missing which if you install it will make the job of fabricating seperation plates at the rear easier...
Posted: Tue Feb 10, 2009 1:26 pm
by Barry
Harry - barely going at all since I got back to work......
Ron - thanks, I have the plates you mention and will have to see whether it is easier to add sections on to close the gaps, or make all new.
Tony Z gave me a few pointers on Friday night, so I will try out his suggestions and see how I get on.
Barry
Posted: Tue Feb 10, 2009 3:02 pm
by vader
I could post some of the pic's I took if you like?
Posted: Tue Feb 10, 2009 3:20 pm
by Barry
Go ahead Vader - I got no problems with that.......
But make sure there is no shot of that special top secret piss yellow 1934 Chev with the built in body lean at standstill.........
Posted: Tue Feb 10, 2009 4:00 pm
by vader
Ok some of them are a bit fuzzy..... They looked in focus when I took them...
Barry I'll keep those "spy" pic's to myself....
This workshop is sooooooooo
BIG dude's that you could hide the entire clone army in there and still have space for the crew of the Death Star!!
She's BIG!
She's BIG! She's VERY VERY BIG!
