Page 4 of 4
Re: My 1964 Beetle, TheQs
Posted: Thu Jul 14, 2011 4:13 pm
a common joke with the VW and Alfa clubs is that the only time the engine doesnt leak oil is when you have run out of oil...
The exhaust is not stock. Its a 4 into 1 system
Posted: Thu Jul 14, 2011 4:16 pm
by fig
Merlin wrote:I don't see any oil anywhere there...that tells me you've run out.
Speak for your own cars Merlin!
Well maintained ACVWs don't leak oil.
Posted: Thu Jul 14, 2011 4:19 pm
by fig
Tony Z wrote:a common joke with the VW and Alfa clubs is that the only time the engine doesnt leak oil is when you have run out of oil...
I think that saying started with aviators, in reference to Pratt & Whitney radial engines. When it's used for ACVW engines, it's either a non-ACVW driver being rude, or an ACVW driver coming up with an excuse for not maintaining their car properly.
Posted: Thu Jul 14, 2011 4:23 pm
I found out that the longer you make the dip stick....
The less oil leaks out.......
Posted: Thu Jul 14, 2011 4:44 pm
by theqs
MINCE wrote:theqs wrote:Merlin, what you mean by the engine has run out of oil, what makes you say that, I check the oil every time I use the car?
i think he meant it as a joke because there is no oil leak
I know, I know ;-p But there is a small leak, admittedly!
Posted: Thu Jul 21, 2011 4:19 pm
by riaanj
I love the earlier 60's models..
Posted: Thu Nov 03, 2011 1:09 pm
by theqs
Hi guys,
Been looking for Seat belt bolt for my Herbie, it looks like a big bolt with a smaller one that bolts to the middle.
By
theqs at 2011-11-03
Posted: Sun Dec 11, 2011 10:16 pm
by theqs
Hey Guys,
Managed to sort out the st st stuttering, replace points was the out come. How easy is it to fit the belt as Herbie did not waant the old one anymore and decided to shred it. If anyone is in my area, pop in and show me what I need to do.
Posted: Mon Dec 12, 2011 12:13 pm
by buggyfan
theqs wrote:Hey Guys,
you can change the belt in 5sceonds with the engine running[if youve got balls of steel
Posted: Mon Dec 12, 2011 12:55 pm
by JonnoDub
That you must show us sometime.
Changing the belt is fairly easy , all you do is remove the bolt on your alternator/generator pulley, there will be a lot of shims and the pulley will split into two halves, slip the belt over the crank pulley and place it between the two halves of the alternator pulley, then place your shims over the bolt and then put the nut back on. Sometimes the belt may be too tight and you may need to remove some of the shims to relax the belt a bit. Hope this helps!
Posted: Mon Dec 12, 2011 1:21 pm
by buggyfan
kids,do not try this at home!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www.aircooledvwsa.co.za/viewtopi ... GE#p208383
Posted: Mon Dec 12, 2011 1:37 pm
by JonnoDub
ja nooit hey , I think I will stick to my method as there are no spares for human parts !
Posted: Mon Dec 12, 2011 7:45 pm
by theqs
Right, will give it a try, I have my Idiots guide and some tools, how difficult can it be, I have already adjusted brakes, replaced stop light switch, and Accelerator cable, next I will be dropping the motor!
