My 1974 single cab fleetline wide load splitty
louisvr45
Re: My 1974 single cab fleetline wide load splitty
Post by louisvr45 »
no wont cut any holes mabi some screw ones for the rev counter, think i will place the other under the center air vent
Junior
Post by Junior »
Sorry its just i have spent the last 2 weeks patching holes that have been drilled in stupid places in the dash in my beetle
louisvr45
Post by louisvr45 »
my second idea but have to drill to much holes
update of where I've finaly placed my gauges:
my seats at the moment:
This is the main reason for redoing my seats:
louisvr45
Post by louisvr45 »
updates on my project
mec oil press
here the 2 gauges are working.
night lights
rear bumpers primered
oil press senders
fuel filter under the tank
louisvr45
Post by louisvr45 »
thread stripped
temp sensor fitted
temp gauge working
new inside door panel
louisvr45
Post by louisvr45 »
Road clearance
All gauges working
2500rpm at 80kph or 3000rpm at 90kph
some short trip photos:
2500rpm at 80kph and after a while the temp stabilze at 100 deg
cruising at 80 pta east bronkhost road
beautifull sun set
Nice to see your single cab is mobile again Louis 8)
louisvr45
Post by louisvr45 »
yes desided wany start using it again. Still need to renew the seats when funds allow it.
Nick Bekker
What model do you have?: 1971
Post by Nick Bekker »
Looks like a fun bus to drive - must be nice to cruise in... :)
No one has lived, until they drove an AIRCOOLED....
louisvr45
Post by louisvr45 »
yes you relax when driving.or cruising
louisvr45
Post by louisvr45 »
some update progress:
Fixed the licence light
Cargo bay Etch primered
Fixed the RG leak
Load bay etch primed
Any one know or have an idea how to seal/weatherproof between the outer bulkhead and the loading bay?
Nice progress Louis. Does it leak into the "treasure chest" area ? Are you referring to the area where the cab "meets" the (upper) load deck area ?
louisvr45
Post by louisvr45 »
Yes
Jolas did you had the same problem?
Its visible from the inside:
louisvr45
Post by louisvr45 »
some more prograss:
getting sprayed(partly)
new bended& home made window latch(took 30 min after bending)
unbended rims - need work
before& after rust removal
stone chipped:
wide bed been bend back& rust removed
