Page 4 of 14
Re: My Lowlight SC
Posted: Sun Aug 09, 2009 11:41 pm
by Chris
Thanks ajvw.
There aren't to many around,and the more I drive it,the more I like it.
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 8:57 pm
by Chris
Got the speedo and fuel gauge working.Now I can see how fast I'm going and if I have enough fuel to keep it going at that speed.Fitted a VDO watch I got from a Beetle,but for some reason it doesn't want to work.Will check it out at a lter stage.
Right hand door window mechanism is also fixed after a cannibalised a beetle mechanism for the winding bit and riveted onto the old mechanism.The bottom part that holds the glass was also badly rusted,so I made a new one from aluminium.
Quater lights can also lock now after I fitted locks I took off old Beetle quater lights.
I had a persisting problem with the engine in that it would start missfiring when it gets to normal operating temp.I changed the coil,checked the timing,set the points,cleaned the carb and also changed the dizzy but it persisted.Then I changed the plugs and plug wires and it was solved.
Started to clean up the engine and replacing seals because of a couple of little oil leaks.Most of this work was done with minimal cost.Mostly secondhand parts I salvaged.
Got an old pull-out Panasonic radio for free and now I have sound too. :hangloose:
Fitted new headlight as the old ones was not working.The parlights still don't work,but I'll get to that this week.
The numberplate was held onto the nudgebar with cable ties.Got a numberplate holder and put it where it belong.
From the DC I'm stripping,I got a good glovebox box and the glovebox cover and fitted that.Now the dash looks complete.
Got the interior light working and also the dash lights.Turns out the the dim and bright turn knob was dirty,and cleaned the sunvisors.
What I still need to do is source a pair of tie rod ends,a new rear bumper bracket and the seats need to be recovered.The loadbed metal has to be replace at some stage to,but I was thinking of using wood.Handbrake cables will come off the DC I'm scrapping and the brakes need a little adjustment.
I enjoy this SC a little more everyday and she carries a 1 ton load with ease.
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:02 pm
by hitlers revenge
How come the speedometer is so bright/white?
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:04 pm
by Chris
The flash. :lol:
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:05 pm
by Donovan D
Flash from camera ?
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:06 pm
by Pine
Nice work! Did you know that a s/c or d/c Bay, being workhorses, came without glovebox covers from the factory?
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:07 pm
by Chris
Yes,fig said so,but I like my stuff covered.
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:44 pm
by beetlefanatic
Mooi Chris!
Re: My Lowlight SC
Posted: Sun Aug 16, 2009 9:58 pm
by lowlight
Chris dit lyk goed, aandag aan detail
Re: My Lowlight SC
Posted: Wed Aug 19, 2009 12:18 pm
by Chris
And here is my number plate I got from Zeroaxe which arrived via TonyZ,via courrier!
Thanks Zeroaxe!! :hangloose:
Thanks Tony! :wink:
Re: My Lowlight SC
Posted: Wed Aug 19, 2009 1:24 pm
by Blitzkrieg
Cool numberplate!
I'm getting Belgium plates for the Fastback :D
Re: My Lowlight SC
Posted: Wed Aug 19, 2009 4:54 pm
by Farhaad
Chris wrote:And here is my number plate I got from Zeroaxe which arrived via TonyZ,via courrier!
Thanks Tony! :wink:
hi chris
cool plate
just out of curiosity to c if i was ripped off, how much including postage. i got one from the uk including the chrome suround
thanx
Re: My Lowlight SC
Posted: Wed Aug 19, 2009 5:52 pm
Zero bought the plate and gave it to me to send to Chris
Re: My Lowlight SC
Posted: Wed Aug 19, 2009 10:42 pm
by Dutch_Diver
I'm stupid I know but was does it stand for? "5UXX033" = :oops:
Re: My Lowlight SC
Posted: Wed Aug 19, 2009 10:55 pm
by Chris
Suxx
Sucks. :mrgreen:
