Regards
New Project for the new year by new member :)
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Re: New Project for the new year by new member :)
Regards
What other people think of you is none of your damn business
- karmakoma
That looks like a bit of fun waiting right there
Imagine hooking up the windscreen washers to the system ,and shall we say, surprising anyone coming too close to the car with a blast of refreshing water
- Dutch_Diver
Congratulations!!!!!! Now that's a real Project....
- sarel.wagner
- Pushrod
If any body can
pretty please....
Looking for this Available in the UK, not in SA.
Regards and thanx
Regards and thanx
- Dutch_Diver
Do you have a maker & model number? I can get delivered to a UK address and then posted to you in SA if that helps....?
- sarel.wagner
- Pushrod
Hi Dutch,
It is from http://www.directcarparts.co.uk/buy-car ... 22137.html" or http://www.motorspeed.com/store_main.as ... ct_id=3908"
Model: Autostyle SYP417
Your help would be greatly appreciated
JamesD69 brings in stuff from UK from time to time, he also offered help. See: http://www.aircooledvwsa.co.za/viewtopi ... =2&t=15094
Regards
Regards
- sarel.wagner
- Pushrod
Hi Dutch,
It seems that James is only in the planning stages for his shipping and ordering process, also not even sure if there will be space to add it into. Can we go ahead with buying and posting. Its about £35. I can do an EFT transfer to you and sort the shipping/postage as well plus some beer mony for the effort.
Regards
Regards
- sarel.wagner
- Pushrod
Update on the project..... Got some panels and both doors from Irna, its from a '66 T1, also the 4 fenders and a deck lid and bonnet.
Thanx Irna, will pick the goodies up this weekend
Spoke to the supplier regarding the HUD display, they will order one for me
and awaiting a rev counter and digital dash so soon the dash layout and design can start.... Got most of the wiring harnass from ISIS, so now the delivery wait is on :/
Rgrds
Rgrds
- sarel.wagner
- Pushrod
Gearbox and wheels
Planning for them wheels
with the 2006cc motor spinning to about 5500rpm on 225/45/18 wheels, what do I need in the gearbox and diff? Bugger??
Regards
Regards
- bugspray
- Floorpan
- Has thanked: 24 times
- Been thanked: 16 times
Im soooo envious of this project. dude when its up and styling, first refusal to buy, and I def.wanna go for a ride.
- sarel.wagner
- Pushrod
Talking about it and planning it, but still have to pull it off
Rgrds
- sarel.wagner
- Pushrod
Gearbox and wheels: Hope to heck I'm not hitting myself with a plank here
Max rpm 5500, speeds in MPH
- sarel.wagner
- Pushrod
And the same again this time cruising speed of 120kph at 3750 rpm, same final ratio of 3.875
225/45/18 I think that might be a bit of an issue to get to fit. Try aim for a tyre with the same OD as stock. Then it will def fit under the arch.
- sarel.wagner
- Pushrod
Tony, if I use standard 6x15's that is same as 150/100/15 in modern speak.
Comparing 150/100/15 to 225/45/18 there is only a -66.91mm difference or -3.13% (smaller)
Comparing 150/100/15 to 225/40/19 there is only a -57.8mm difference or -2.7% (smaller) or in the 19" version within 3kph at the same rpm.
Ideally it needs and 8" or 8.5" wide rim or even 9" Now the issue is 150mm wide vs 225mm wide. Will have to play with the offset and drive shaft length as well as beam width. The '67 comes standard with ball joint front end and dick brakes in front, drums rear side. The idea is to upgrade the front disks and do disks in the rear, also to slam it, as much as possible with these tyres.
Any insights?
Rgrds
Any insights?
Rgrds
