Page 4 of 13
Re: Project Fleetline
Posted: Sat Jun 18, 2011 11:58 pm
by sean
jolas wrote:
fig wrote:There's no difference between the front engine tin on a Beetle and a split bus. The tin is different between single and twin port (twin port has a cut-out for the oil cooler air outlet; you can cut a SP tin in need). The early type1 engined baywindow buses have a different front tin to the Beetle; it stands a bit higher. You can see how VW simply welded an extra bit on top.
I took this pic a few years ago when I was trying to get my 1970 Westy on the road, did'nt realize there were so many different types ....
The middle "tin" is the one Fig is referring to
Thanks Paul
The one I need is the third one with the ducting for the oil cooler. The fan shroud on my motor is also a bit beaten up, so in need for one of those too.
Volksie World say they have all the pieces around. I must just make a trip through there some time to collect it.
Posted: Sun Jun 19, 2011 12:21 am
by Donovan D
sean wrote:
Splitz wrote:Are you using the NS4 primer ?
Howzit Splitz
No, it's 2K MS primer.
I think its the one I used and had some problems after a year with the paint.
Internet wrote:Check if the primer you used is the normal 2k or the 2k filler primer. If it's filler
primer you can use dry paper to smooth. Never wet sand
2k it absorb water like a sponge right to the metal.
I wet sanded mine and the primer absorbed the water. I did not know about the primer absorbing the water.
The paint started bubbling in some areas as the primer was not completely dried right through before applying the paint and the clear coat, even though it did not look wet at all.
Im no expert in this field thats just what some pro's told me when they saw the paint and asked about the prep work
You can see the fleetline build at http://s725.photobucket.com/albums/ww25 ... Fleetline/ ....if you havent seen it already
Posted: Sun Jun 19, 2011 7:57 pm
by sean
It's the plain 2K primer, not the filler one.
I will watch out for this, I have used it many times with no problems.
Thanks for the link, first time a saw this bus was at the Panarama or Tyger Berg wheels show a few years ago. Pity it was sold after all that work that you put in. Where was it from when you purchased it?
Posted: Sun Jun 19, 2011 8:10 pm
by Donovan D
sean wrote:Thanks for the link, first time a saw this bus was at the Panarama or Tyger Berg wheels show a few years ago. Pity it was sold after all that work that you put in. Where was it from when you purchased it?
Yes, that was quite a while back. I got a lead on that bus from Erus, it was someone he knew from Hermanus. It was just standing in a garage.
It was sad selling it after all the effort and work, and its such a solid rust free bus
But atleast its back on the road again...well sorta
Posted: Sun Jul 10, 2011 10:50 pm
by sean
Preparing for the final coat of paint, this has to be one of the worst. It takes forever to sand down the entire bus.
Bottom part completed
Posted: Sun Jul 10, 2011 10:52 pm
by sean
Final product, this makes that awful work seem not so bad. I am quite pleased with the colour scheme. It is always a bit tricky choosing from a colour chart, but what I had in my head managed to turn out on the bus!
Posted: Mon Jul 11, 2011 8:15 am
by jahjuan
Very, very nice! The colour looks cool, you must be pretty chiffed with yourself.
Posted: Mon Jul 11, 2011 8:49 am
by YvaneS
Looks great keep up the good work!
Its cool if you have the know how and tools to do these things yourself!
Posted: Mon Jul 11, 2011 8:59 am
by fleetline15
Sean great thread . I have too like the colour here is a shot of mine its not far ahead of yours needs the interior to finish. BTW what colour is yours? Mine is Savannah beige and is actually a little darker than it looks in this pic.
Keep up the good work Mitchell
the red beltline insert is a must foe this colour.
Posted: Mon Jul 11, 2011 9:31 am
by jolas
Sean, that looks great man :shock: Major progress made dude :hangloose:
Posted: Wed Jul 13, 2011 3:55 pm
by lowlight
Very nice
Doen so voort.
Posted: Wed Jul 13, 2011 6:40 pm
by CooP
WOW :hangloose:
Posted: Wed Jul 13, 2011 8:32 pm
by sean
Thanks for all the comments.
The bus is currently on stands now while I am having the rims sandblasted. In this time I am now stripping all the suspension out again and finishing it underneath. It was cleaned up underneath earlier on already so I just need to finish coating it with chassis paint underneath.
I am picking up all the mechanical components on Friday. New tie rods, drag link, shocks, brakes, brake cylinders, master cylinder, flexible brake hoses, boots, gearbox mountings etc. etc. that I can complete the underneath.
The engine will be next, all the tinware must be blasted and powder coated and other parts cleaned up. Fuel system too.
Then lastly will be final assembly, the best part for last. All the body components, windows doors and hopefully it will all come together beautifully.
Posted: Tue Jul 26, 2011 12:45 am
by sean
Some of the spares that have arrived so far.
I bought these few crates of spares over the weekend, mainly for the hubcaps, intake manifold and starter. The rest is beetle, so I will have to find another home for the rest.
Posted: Tue Jul 26, 2011 12:47 am
by sean
Some before and after pictures. The brakes are completed; seals at the reduction boxes replaced, all the new parts received so far have also been fitted. Still just waiting for the tie rod and drag link to be completed after having new ball joints welded in by Flat4 Racing.
