Ok at long last i iam done with the beetle with what i wanted to do ...... cept a couple very little things .... ( i got to keep my hobby alive now don't i ? )
Well this is going to be a looooong write up so get a beer and get comfortable
1. Replace TP heads
2. Take donor dash from another beetle and fit to this one
3. Install guages
4. Fit SP beetle steering
5. Center console
6. Redo wireing that turned out in making and replacing the whole bloody harnass from front to back
7. Fit the leather seats i got
8. Fit back seat seat rest and kick boards
9. Fit battery cutoff switch
10. Do something about horrible tar board firewall
11. Fit reverse light switch and lights
12. Add hazzard switch and circuit
13. Replace broken indicator switch/arm in steering
14. Fit decklid spring
15. Install radio/Speakers
Well from those who followed my progress with my wife's beetle , i sized the bloody big end bearings , then started with another engine for the beetle , finished it and put it in , started her and had a bloody awefull misfire , feeling around i realised number 4 plug was loose . Couldn't understand why so took engine out again . Sigh and yeah the damn insert was loose and on closer inspection realised that the head was cracked next to the insert anyhow .
1 Refurb TP heads
Uploaded with ImageShack.us
Lucky i had 2 more TP heads but needed inserts put in , so i send them to a engineering comp and had inserts done on them ( sry forgot to take pics) anyhow assembled the engine once again , and then decided well seeing as i am doing this once again i'd rather do what i was going to do anyhow ..... this is the list
2. Dash before :
Donor dash :
By timeman007 at 2011-05-15
Fitted after covering with cloth as it was very cracked and broken from the sun and rain in donor beetle
3/4 Fit guages and fit sp beetle steering
5. Centre console
Used a console from a VW fox
Front Console rough template that i will use and make one from plywood and also cover with the material like the dash
7. Fit seats
Before
Donor Seats
Fitted after a lot of swearing and sweat
To be Continued
