Fomula Vee Rebuild
JamesD
Been thanked: 20 times
Re: Fomula Vee Rebuild
Post by JamesD »
Stripping, cleaning, spraying. 3 of the 4 corners are finished.
Things to do still:
1. Last corner to strip, clean and spray
2. other rear brake overhaul
3. set and bleed rear brakes
4. New 8.8 bolts and lock nuts on all suspension parts
5. breather pipe + catch can for gearbox
6. paint gearbox.
7. bottom mounts for seat
8. Fuel tank (need to decide if we will keep the old one or make a new one)
9. Mount oil cooler and run piping
10. Tune Engine
11. finish rear cowling
12. make up new mountings/mounting method for the nose cone
From fastest to slowest:
'75 SP 1600 with a few mods
JamesD
Post by JamesD »
So, last corner, every thing was going fine and then a siezed slave cylinder... Stripped, cleaned and lightly honed. just need to put it all back together.
So out of the 4 cylinders, 2 were partially siezed and one piston was broken. so of the 8 pistons 3 were stuffed. this car should have much better brakes now!
Has thanked: 425 times
Been thanked: 543 times
Well done.
Always good if you can BRAKE for a corner. Come in handy in V racing.
:lol: :lol:
JamesD
Post by JamesD »
Todays progress...
Bad Ass Bob
Post by Bad Ass Bob »
Hi
where did you get your seat from and would it fit in a Lotus ????
BAB
JamesD
Post by JamesD »
Sup Bab, yip, I have it in my birkin, so if it fits a Birkin then it should fit your car fine as well! Most of the racing guys have them, in fact almost all. They are a tight fit ass wise but are super comfortable! One of the guys i know had his padded and covered for his road car. Clive Wilmot stocks them - racekit.co.za, Garreth Taylor stocks them too - Image
JamesD
Post by JamesD »
You guys cant say you dont get pictures!
now thats looking good.
Close to going racing.
Well done.
CooP
Post by CooP »
Fantastic job JAmes. Now for a few current action shots...
Size does matter
JamesD
Post by JamesD »
Action shots are a no go, we having a few bad suspension problems currently. Need to go rip a few of the suspension leaves out, all but 4 or 5 infact. and add a dampener between the rear suspenion and body. The car has a tendency to cock a front wheel around corners and then not put it down again, oops. But the next two weekends are to be spent on my race car. so the next update may only be in a while unless my father and brothers play with the car...
CooP
Post by CooP »
I wait with bated breath, congrats on the work so far.
Size does matter
JamesD
Post by JamesD »
Thanks Guys :D
I will probably bring the car to air cooled heritage day and/or Ferdi's. Question is drive it or trailer it :wink: heritage day is only 10km away :mrgreen:
Wentzel
Been thanked: 13 times
Post by Wentzel »
Looking very good James! Looking forward to Ferdi's myself so I will see you there. Hope to have a closer look at it too.
Oxyboxer Project
JamesD
Post by JamesD »
Well since I put my car into the wall at Topgear festival and then screwed up the gearbox of the tow car on the way back it gave me some time to get busy on the Vee again. The front suspenssion was stripped and a leaf spring or two was removed. Spacers added to compensate for the removed springs. did not have too much fun, but the suspension is feeling reasonable so far, just need to finish assembly and then give it a try.
MarshallGTi
Camshaft
Has thanked: 7 times
Fomula Vee Rebuild
Post by MarshallGTi »
Unfortunate news about the race car, what happened?
Sent from my iPhonebooth using Tapatalk
Ryan Marshall
3250
