Warwicks Split
Warwick-Lowlight
Re: Warwicks Split
Post by Warwick-Lowlight »
So breather tube rubber it is thanks HR
Warwick-Lowlight
Re: Warwicks Split
Yet onother early start with the chickens
What to do
well started playing with some door hinge repairs
A bit of heat and then some oil and then open and close
Next to repair some of the cracks
Cant seem as to wonder why someone would not just put a little oil and then this would never happen :x
beforeImage
By lowlightwarwick at 2012-06-19
After
The challenge
This one is loose inside and out
Need to get the correct clamps
Will try secure the inner first as the outer has torn quite badly
Plan will be to get inner on then test on door and bash the bent away bits on the outer and fix - well thats the plan anyhow
Warwick-Lowlight
Re: Warwicks Split
Well got the call from the doctor -Jurgen :shock:
Was not listening properly as I have had a mare of a morning - what with a load of chickens getting stuck on the pass :evil:
So as Jurgen was telling me that the state of the engine was bad I was already throwing it in the dam because of the previous few hours
Being slightly more attentive to the details
Bad for Grand Slam and good for me :D
Seems the previous owner was not lying when he said he'd only done 500 km or miles with the engine
For those of you's that know Mr Jurgen - it does not happen that an engine will be sommer put back together again
Luckey the Abbatoir for the birds is right nexto the shop so will have to go and have a look and get some pics
will replace with new rings and looking for a 200 flywheel
More to follow after the visit
8)
Warwick-Lowlight
Re: Warwicks Split
Well its all true
New rings a bit of spitt and polish
Only dirty thing about -is that finger of Vaders on the crank
By lowlightwarwick at 2012-06-20
Thank god for small mercies - needed that after the day I had 8)
Re: Warwicks Split
:hangloose: great news - you're saving a bit of cash there Warwick
splitbusahollic
Facebook: vintage kombi
Has thanked: 87 times
Re: Warwicks Split
Post by splitbusahollic »
jolas wrote: great news - you're saving a bit of cash there Warwick
Nope He's not ! :lol: :lol: :lol:
the visit to Adendorf's will take care of that pretty quick ! :lol: :lol:
and when they are done with him....
some :mrgreen: panels !!whoooha !
vintage kombi.co.za (Website)
vintage kombi on Facebook
Warwick-Lowlight
Re: Warwicks Split
Damn straight there guys
Glad to get a bit of an " In " bonus after what was given out for the bus :lol:
Warwick-Lowlight
Re: Warwicks Split
Regarding the pannels and floor bits that need come off
I feel like a teenager thats trying to work out the bra hinge
Dont want to be to rough but I know the bugger must come off :lol:
Had a look at a cool project on the Samba but yes like a ^&*%*&%% did not mark the page
will have a look to see if I can track it down
Warwick-Lowlight
Re: Warwicks Split
Must be havin an early moment
here it is http://samba.rustyvw.org/
Must admit do like the cage the dude made - roll stand
Seems I might be rustling thru the scrap heap and build me one of those
splitbusahollic
Re: Warwicks Split
Hey Mr. W
here is another thread to look at a great restoration....these blokes went a bit over the top with this bus :shock:
but the general resto info is good and one can learn from some of this.... :wink:
go search : 59 11 window splitty custom resto
have fun !
Warwick-Lowlight
Re: Warwicks Split
shot Jacques
Seems a hole saw - air chisel and allot of time needed
Maybe I should have got that coke cooler
Looks like one could get thirsty
Coke - dude
No drinking and working with power tools without the protective gear :hangloose:
Warwick-Lowlight
Re: Warwicks Split
Well all I can say is that a man cannot have enough tools !!!
Adendorfs 1 warwick 0
Seems Ill have to go there with more bucks for the second half
Anyhow Air tool kit -got
Last post on pesky little buggers - having to moer the old impact tool !
One by No8 socket and impact bit and tool and you are laughing :lol: :lol:
Driver door hinge bolts not even a minute
Tommorow will be play day with the rest of the bolty things and maybe even get the front end off
The weapon
By lowlightwarwick at 2012-06-22
The battle done
More to come
Also got a sabre saw with spare blades - no stopping me now
:hangloose:
Warwick-Lowlight
Re: Warwicks Split
Play with the bolty things yeah right
Cargo door front -no problem
Rear top no problem
Bottom one broke the impact bit on the top one so weld on a new head as you know you need the length to get past the side sill
Last one totally screwed so had to go old school and weld on a bolt and slowly ease the %$%%#@$ out
By lowlightwarwick at 2012-06-24
Problem - back screw bit came out as well - help :zhelp:
Before
After outside
After inside
Snapped hinge before
And after
Tried rear doors and pop outs but seems will need some more patience
Got roof lining out and hit back the dings from the thorn tree lying on top
:hangloose:
Finished front doors today
Welds on
Warwick-Lowlight
Re: Warwicks Split
This here, is Hitler's Revenge.
From Sean
So true
So ta ease the removal came up with a cunning plan as lying on the floor and trying to get the gearlink loose was trouble enough
Use your head warwick its a farm !!
So one by forklift with fork extentions
One by Apple bin
And there you have a much better space to work with
Now just to see if this helps getting that damn gearlink loose :evil:
By lowlightwarwick at 2012-07-26
Warwick-Lowlight
Re: Warwicks Split
Just for memory if this gets lost
Gear link removal
http://www.aircooledvwsa.co.za/viewtopi ... =4&t=25664
Well got the link loose so can proceed with the front axle and get him out
Having so much fun with the new work zone
seems much better standing up and working than laying on the deck
So next task will be to get the back bits out -gearbox and all
Will make job easy for cleaning
