I'm refering to the old clearcoat, that was originaly on the car.Kafer74 wrote:Hi Rui, the clear coat has not been applied yet, it was / is only the paint itselfcalooker wrote:That "cracking" is what happens when primer is applied directly onto a layer of clearcoat, the prep for priming was not done properly, clearcoats need to be removed entirely not just flattened as they probably did in your case.
1960 Beetle called Oupa
- Been thanked: 98 times
Re: 1960 Beetle called Oupa
The clearcoat should be removed throughout the body, to do it right it should go down to metal everywhere to stop any fresh paint from cracking / lifting / flaking a few months down the line.Kafer74 wrote:Thank you for the info Rui.
I saw this happen to forum member's bus, not the first time either, bus had to be entirely redone after only a few months, huge additional cost as the bus had to be srtipped down and everyting re-done as cutting corners at prep stage will cost dearly later. In a way you are lucky it happened now.
Prep is way more important than the final colour coats.
Also, beware of paint stripper, if it is not properly neutralized, it will carry on reacting in damp weather, and lift your paint, as well as start rust spots under the paint.
You will see here on the forum, the guys that do there OWN cars, as my self, sit for weeks, with a heat gun, and scraper to remove the old paint.
Have a Beetle that was painted by and "Expert" (I bought it like that) that is showing spots, lifting and rust marks from Paint stripper.
You can not "Just wash it off" with a hosepipe, as it sits in the old rust holes in the steel, it one hell of a job to kill the stripper.
No, best is take the car down by hand to bare metal, then flat it down, then do a rust converter, then an etch primer, then a filler primer, then the base coat, then the clear coat.
A quick buff and you smiling.
- Kafer74
- What model do you have?: Beetles
- Has thanked: 37 times
BATTERY TRAY
As you would know, a Beetle of Oupa's age with a solid rust free battery tray is a very rare find these days. Oupa also suffered from the same disease but surgeon Joggie successfully completed the operation and the battery tray section is better than new.
JOGGIE
Enjoy the Ride
1970 Westie called Ben
- Kafer74
WAX ON WAX OFF
Joggie started sanding some of the panels and applied polish.
Enjoy the Ride
- Retro13
- What model do you have?: Kestrel Buggy
- Has thanked: 7 times
- Been thanked: 3 times
Holy Cow!!! That is unbelievebly shiny (me like shiny
It almost looks like black chrome. Joggie is one very talented individual, well done.
This car is going to look AMAZING when it's done.
Never ride faster than your guardian angel can fly...
- Kafer74
The FIX
The panel has now been repaired and sprayed. Except for the doors, Oupa has been completely sprayed and polished. I have ordered window rubbers from Rui and once the shipment has arrived and I have collected, the roof lining can be put in and window rubbers fitted.
Enjoy the Ride
- vw59beetle
- Has thanked: 39 times
- Been thanked: 40 times
Lyk goed Hennie.Kan nie wag om n breakfast run saam met julle te doen of nog beter, die drive-in.
Wernher
Wernher
- Kafer74
90% THERE
Some more photos...
Some more photos...
Enjoy the Ride
- Kafer74
Dankie Wernher, ek kan ook nie meer wag nie. Dinge gebeur nou met 'n spoed en die duur gedeelte kom nou met al die nuwe parte vir assembly. Hopelik gaan hy betyds klaar wees vir Ferdi's Swop Meet, maar my doelstelling is om Oupa heeltemal klaar te he vir Aircooled dag.vw59beetle wrote:Lyk goed Hennie.Kan nie wag om n breakfast run saam met julle te doen of nog beter, die drive-in.
Wernher
Enjoy the Ride
- Kafer74
Odds & Ends
Enjoy the Ride
- Kafer74
ASSEMBLY STARTS!!!
The eagerly awaited assembly of Oupa has started. This time it is not Volkswagen Werke West Germany but Joggie Werke SA
Enjoy the Ride
- Kafer74
Oupa Eagerly Awaits Further Assembly
Enjoy the Ride
- Kafer74
ASSEMBLY Part II
Bring on the Bling!
Bring on the Bling!
Enjoy the Ride
