1972 custom crew cab FOR SALE
JC Rousseau
What model do you have?: 69,75split,75,79scab
Has thanked: 85 times
Been thanked: 16 times
Re: 1972 custom crew cab
Post by JC Rousseau »
Some before pic`s
After
61 Beetle aka klapperkiste
68 Squareback viewtopic.php?f=23&t=34408
69 Kombi
72 Crew cab viewtopic.php?f=23&t=32846&hilit=1972+custom
75 Fleetline panel viewtopic.php?f=23&t=32485&p=309053#p309053
79 Single cab
try Wurth
JC Rousseau
Thanks Tony ,but thy were the first people i phoned and its a no go.Thy only stock the covered panel one that slides in.
69 Kombi
79 Single cab
JC Rousseau
This took me more than 6 hours to do by hand,the gunk was like concrete, engine cleaner warm soak,petrol soak, high pressure cleaner NOTHING WORKED
I have been looking for the reason way the bus went of the road into the garage(1982) and only came out when i bought it ,well to date the only thing i can find is that the advance in the distributor is locked shut like fort Knox`s.
So the PO must have given up struggling i think
69 Kombi
79 Single cab
mooi man!!!
1 word when it comes to cleaning heavy muck like that - paraffin
that said, you did a fantastic job!
gusbus
What model do you have?: 1964
Post by gusbus »
Also need some door cards. Who cut those? Where can I get?
JC Rousseau
I cut them for myself at the moment , once i get the perfect fit i will put some up for sale(nobody likes a bad repo fit)
The super wood i cut in the photos is just a sample and for use when covering the panels,i will be cutting birch panels and then sanding sealer them for my crew cab
69 Kombi
79 Single cab
JC Rousseau
So the day has arrived to put my engine back :D :D :hangloose: :drunks: :drunks: :drunks:
Will post pic`s a bit later
69 Kombi
79 Single cab
Those door cards are the shizzle! :hangloose:
Wouldn't mind a set. What thickness are they?
JC Rousseau
WELL as it go`s with vw`s
This is how far I got :flash: :flash: :flash: :flash: :finger4u:
So when I wiped the bellhousing clean just before the fit, low and behold the starter bush was in pieces :drunks: :drunks:
Lesson learnt, clean the bellhousing when removing engine
Engine transport at its best
69 Kombi
79 Single cab
JC Rousseau
So we back on track ,thanks Juergen :deflag:
69 Kombi
79 Single cab
jmvv
Been thanked: 24 times
Post by jmvv »
Nice to see light at the end of the tunnel.
We follow your thread with great interest.
JC Rousseau
So he is running and driving :hangloose:
Just a few things to sort choke not working nice,timing reset and adjust carb .
69 Kombi
79 Single cab
Donovan D
Has thanked: 150 times
Been thanked: 73 times
Post by Donovan D »
This is really a cool crew cab, saw it on Saturday and really dig it ! Forgot to get the timing light on it JC.
JC Rousseau
No worry's lots of time to play, nice meeting you in person donovan
69 Kombi
79 Single cab
