blow through setup through a idf downdraught
dubster
Post by dubster »
i dont know then il have to get the info for you and post it...
dubster
Post by dubster »
Tony i did it again...go to GOOGLE and search exactly this..."blowthru pict34 again & details"it should be the first link that is found...thanx
I googled it get the link but don`t find the post 34pict :x
Thats the difference, your first post said "blowthrough pict34" but the search needed "blowthru pict34"
The idea can work. But it seems like you are in for a sh$t load of work. First you have to modify the carb - assuming you know your way around a carb inside out and you have the tools needed to do the mods. Then you have to experiment with different jets by modifying your own as you cant just buy different jet sizes for that carb.
Good luck to you if you want to do this. I'll be quite keen to see it work, but I dont play with carbs.
dubster
Post by dubster »
yeah sorry i realised that thats why i posted it blowthru the second time...yeah it probaly is but maybe i can get in contact with that guy and get al the details im sure he wil help...but thanx for checking it out 4 me...
IMPI
What model do you have?: sp2
Been thanked: 78 times
Re: blow through setup through a idf downdraught
Post by IMPI »
The reason why it is inadvisable to run an intercooler downstream of a carb: fuel +oxygen+confinement= Bomb
The brazillians used the twin carbs on the SP beetles for blow through systems for years
Best book on the subject is TURBOMANIA>
