Page 35 of 104
Posted: Wed Feb 10, 2010 1:41 pm
by Dutch_Diver
Going to collect today....
Posted: Wed Feb 10, 2010 4:42 pm
by vader
I left it at the sea cause it doesn't have quite enough rust on it....
Posted: Wed Feb 10, 2010 6:26 pm
by bugspray
Fitted a new battery 643 yeah, so have enough juice to run the gadgetry that will find it way into him. Tried taking it in for the COR, but the idle was fuct, realised thta my idle jet switch is fried, tried sorcing a new one, no damn luck!! Grr. Running it with a high idle after settint the screws on some gas guzzling proportions, fixed the damn wiper motor and arms, yippie we have wipers! Sooo stoaked that its coming together. The headlight bulb decided to retire today, gonna get me some osram cool blues tommorow. Oh also tightened the front bumper. Looks kak but has to be on. All in all a good aircooled day.
Posted: Wed Feb 10, 2010 6:32 pm
by ViperR
Jacked up front suspension & removed the wheels.
Posted: Wed Feb 10, 2010 7:34 pm
by Colin
i drained the break fluid and replaced the seals on the master cylinder and put it all back together then played a game called pump release. now i must find time then get slave cylinder kits and do them.
Posted: Wed Feb 10, 2010 7:59 pm
by Hloni
Calooker, pics bru, pics!!
Posted: Wed Feb 10, 2010 11:06 pm
eben wrote:Tony Z wrote:Engine in... engine out, gearbox mount bolts hitting flywheel, engine out
grind bolts
engine in, kaefer cup brace hitting exhausts... engine out - remove keafer cup brace. Swear a few hundred times.
engine in
car falls off jacks - quickly push car back up - no damage.
rear brakes on
Wheels on
tighten wheel bolts, car falls again this time, need to jack car up
torque castle nuts
push car out of garage and back in to line it up again
theorise about how to remount kaefer cup brace.
Even had Vader come around for moral support
Trestles?
yea, thats what I meant.... had it on 4 car jacks... very uneven floor
Posted: Wed Feb 10, 2010 11:21 pm
installed oil bypass kit. Holes on aluminum plate dont really match the block. Hole on gasket really dont match either. Outlet port has tapped 1/4" BSP and a plug supplied. hole is tapped too deep and thus the plug actually blocks the oil passages... so I had to arrange another method of blanking the hole....
Pretty up fan housing and cut it to fit properly
install carbs
test starting circuit and wire in start switch as temporary measure
test radio which was installed a few days ago
fit carbs and fan housing
fill gearbox with oil
fill engine with oil
swing over engine until filter is filled and pressure starts to build - recharge batteries (used 2 for the priming)
fit engine tin and wire up engine
organise some nice little extras that some of you might notice at George
Finally start engine - in a block of flats at 1930 without the silencer fitted - just a tad loud but sounds good!!!
Posted: Thu Feb 11, 2010 8:08 am
by calooker
Forgot to add, rear bumper and decklid is on, almost lost a finger doing the decklid spring when it jumped out during the install
Posted: Thu Feb 11, 2010 11:38 am
by zubz
calooker wrote:Forgot to add, rear bumper and decklid is on, almost lost a finger doing the decklid spring when it jumped out during the install
Rui, do you own a Notch? is a 1964 Notch rare?
Posted: Fri Feb 12, 2010 6:08 am
Woke up, had a small snag list to go thru...
then found a small oil leak - EMPI fan thermoswitch is leaking. Put spanner on, switch breaks off. Cannot source replacement... blank off switch and wire fan directly to ignition source.
install silencer
fit new seat covers to pretty up the inside a little
neaten up engine bay for show
start car - nothing.... turns out another compufire unit is dead - this shiv is getting expensive.
start car... synchronise carbs
test for gears in parking area and test brakes. All seems good.
Install boot lid after giving it a good clean
take for test drive - all good except I cant get enough fuel to the engine - going lean after a few seconds at full throttle
Test drive over - go visit a friend. Get to his house on other side of Cape Town....
Clutch cable breaks DAMMITits now 20:00
Tow home
Posted: Fri Feb 12, 2010 10:04 am
by zubz
Tony Z wrote:Woke up, had a small snag list to go thru...
install silencer
Tow home
EISH, I feel your pain..hope you come right...
Posted: Fri Feb 12, 2010 10:08 am
by calooker
zubz wrote:calooker wrote:Forgot to add, rear bumper and decklid is on, almost lost a finger doing the decklid spring when it jumped out during the install
Rui, do you own a Notch? is a 1964 Notch rare?[/quo
Yes, I have a 64 Notch with the rare bush button dash, not been driven in almost 2 years, but found a nice roof rack for it and trial fitted it last night, needs a little modding, I will make it work.
Posted: Fri Feb 12, 2010 10:13 am
by calooker
Fitted gravel Guards on the 58 last night, found the source of a nigling oil leak. Fitted the running board trim, looking good.
Posted: Fri Feb 12, 2010 9:13 pm
by windtramp
Dutch_Diver wrote:Took Bobbie for the first run from Strand to Paarl and back.....about 150km and used over 20 litres of petrol....
yikes ....
did you have the handbrake on the whole way??
