New Project for the new year by new member :)
Re: New Project for the new year by new member :)
For what its worth, my bug has 205/65/15 and they fit pretty well.
I'll be stepping up to 215/45/17 when I can find mags that I want to buy,
- sarel.wagner
- Pushrod
- What model do you have?: T1 x 4, Split SCwide
- Facebook: http://www.facebook.com/sarel.wagner
- Been thanked: 2 times
Circumference is -174.98 or -8.18% underTony Z wrote:For what its worth, my bug has 205/65/15 and they fit pretty well.
Circumference is -105.25 or -4.92% under
Is your fenders and front beam all stock?
Rgrds
What other people think of you is none of your damn business
- sarel.wagner
- Pushrod
Started designing my wiring harness, doing it in Visio. Lots of things to be drawn, it is a huge task!
Battery, Starting & charging circuit (Batt, Alternator, Starter, EFI & Ignition)
Safety systems (Wipers, horn, brakes, indicators, park lights, headlights, stoplights, daylight running lights) Yes its gonna have LEDs
Interior systems (Instruments, Starter switch, navigation & ICE, door switches and interior lights, electric seats, alarm & immobilizer, fresh air fan assisted cooling)
Monitoring and programming systems (USB interface to CAN bus & Instruments, RS232 to EFI system)
Rears are std, fronts are flared a fractionsarel.wagner wrote:Circumference is -174.98 or -8.18% underTony Z wrote:For what its worth, my bug has 205/65/15 and they fit pretty well.
Rgrds
- sarel.wagner
- Pushrod
Electrics being
into shape:
Yes I know, it doesn't make any sense yet. Its not complete
This is to give you some idea.....
Rgrds
into shape:Yes I know, it doesn't make any sense yet. Its not complete
Rgrds
- Has thanked: 19 times
When you visit we can chat some Transmissions
You mentioned some where play with the axle lengths only 2 lengths available but much nicer with nice wider fenders as I am running 265 35 18" on the back of the fly
- sarel.wagner
- Pushrod
Hey that will be great, taking a look tomorrow at an IRS trans, with rear disks, no calipers tho. Anything to look out 4?
sarel.wagner wrote:Hey that will be great, taking a look tomorrow at an IRS trans, with rear disks, no calipers tho. Anything to look out 4?
Just check the code on the bottom if it is a BA it is most probab a BRAZILIA trans which is no good for power thas had Universal joints and the guys convert then to CVs
With rear discs is that 944 back end then
- sarel.wagner
- Pushrod
Nope, disks from Volkspares, thanx will have a look then.
- sarel.wagner
- Pushrod
Found a model that looked about right, some pics for some ideas: Chopped, large wheels....
- sarel.wagner
- Pushrod
Bugster. a new Project for the new year
Thanx bud
Will take some proper pictures 2morrow and post.
Rgrds
- karmakoma
I have seen that model. Looks pretty cool.
Build it! Would be awesome.
I am not usually a custom fan, but a custom bug, built right
- Dutch_Diver
Get buying and cutting....we want to see pictorial progress of the real thing, PLEASE......
- sarel.wagner
- Pushrod
Quick price breakdown:
R 6000 '67 with ball joint front end, no engine
R 2800 Doors, fenders, lids
R 16000 Can bus Wiring system with remote key fob
R 11000 Digi-dash with logger
R 3800 Rev counter
R 4300 Heads Up Display
R 1500 rear disk breaks IRS
R 45 400.00 Total spent this far and I have not really started yet
Please tell me if my estimates below is out and by how much please?
Still to do: (Estimated value)
Chop (???)
Panel beating & new repair panels if required (???)
Paint R5000)
Spray (???)
Wheels & Alloys 19" R15000)
New front seats (R6000)
Modified rear seat (R2000)
Interior in Leather (R8000)
Build a dashboard (R4000)
Move backwards by about 200mm the steering wheel, pedals, gear lever, hand brake and front seats (???)
Extend dash controls by same amount (R1000)
Install ICE (R20000)
Fuel injection (R16000)
Alternator (R3000)
New rear lights (R4000)
Front lights (R4000)
New glass all round (???)
LED running lights (???)
Overhaul various parts (R15000)
IRS gearbox (???)
Bugger to fix gearbox (???)
IRS Conversion (???)
Motor (???)
Will add this up as I get the estimates closer to where they need to be... But the rest already more than R100K
Rgrds
