Help rescue a Bay Camper - please
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Help rescue a Bay Camper - please
The 1600 bellhousing has a shorter input shaft too than the 1800 or 2000 bellhousing. 1800 had the longer shaft but the shorter bellhousing where the 2000 had both extended. Not sure if that starter will engage correctly with the smaller 1600 flywheel.
I would personally get hold of 1600 bellhousing, input shaft and starter to simplify the setup.
- didi
- Has thanked: 9 times
- Been thanked: 37 times
Thanks for all the advise and encouragement guys
_______
- didi
Just a quick update, I turned the key last night and it fired up. Nice milestone to have the engine roaring in the back since it was standing for almost 10 years.
_______
- Klaus
- Has thanked: 13 times
- Been thanked: 11 times
Good milestone to keep you motivated in the project
Well done and enjoy
Well done and enjoy
- didi
Thanks Klaus and CooP!
_______
- Been thanked: 322 times
Brilliant Didi. Great save!
- didi
Thanks Fig, there is still a lot to sort out, but the list is getting shorter. Next will be sorting out the electronics, brakes and suspension, doorcards, kickpanelsand then off to the roadworthy.
_______
- buggyfan
- Long Block
- Has thanked: 95 times
- Been thanked: 87 times
does this mean youve managed to get registration papers from the previous owner aswell?didi wrote:Thanks Fig, there is still a lot to sort out, but the list is getting shorter. Next will be sorting out the electronics, brakes and suspension, doorcards, kickpanelsand then off to the roadworthy.
- didi
I have to get the bus to roadworthy, police clearance and weighbridge still to re-introduce it. Drove it around in the yard
Here is a photo from the back with the engine in
_______
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
- didi
Hi Jolas yes I still have Norm, the '72 Westy as well. Not sure what I'm gonna do once Norm is finished with the bodywork. I think I will restore Norm while I'm driving around with the '70 and then decide from there.
_______
- didi
I am busy making the doorcards, kickpannels etc.
_______
- Junior
- Pushrod
- What model do you have?: Had a 75 + 64 beetle
Really nice job!!!
are you going to cover the door panels your self or get it done professionally?
- didi
I am going to do it myself. I hope I do a half decent job. There is no fun in paying someone to do it
_______
