"Eva-Ann"
- Batman
- What model do you have?: 1971 Beetle 1600 TP
- Has thanked: 4 times
Re: "Eva-Ann"
Fitted the engine bay rubber last night. Was easy and painless. Removing the old rubber was a bit of a mission
- Batman
Re: "Eva-Ann"
She got a new parking spot at home. Broke down the boma to make space
Terry Phillips
- Has thanked: 193 times
- Been thanked: 121 times
Re: "Eva-Ann"
That sounds like a plan I wonder what my wife would say if I knocked the Lapa down to park some cars.
- Batman
Re: "Eva-Ann"
A man's gotta do what a man's gotta do ...Terry Phillips wrote: Wed Jan 23, 2019 11:20 am That sounds like a plan I wonder what my wife would say if I knocked the Lapa down to park some cars.
- Has thanked: 425 times
- Been thanked: 543 times
Re: "Eva-Ann"
You need to see the positive side of this issue.
One can see the car nicely from the couch, and not from the bedroom ....
- Has thanked: 141 times
- Been thanked: 101 times
Re: "Eva-Ann"
I can't see how you can remove old engine rubber and install new one with engine in place.
- Pushrod
- Been thanked: 112 times
Re: "Eva-Ann"
With,....extremely painfully ,...broken knuckles and not enough water to clean you off,..and your mouth,... because of the. Language that came out of it!!!!!!,.....
- Batman
Re: "Eva-Ann"
Previous owner went a bit mad with a black can of spray in the engine bay, i'm busy cleaning the airfilter box.
Cleaning the box clips .....
Re: "Eva-Ann"
Not too difficult. Lots of good guides online. It is best to do the job on a nice sunny day. Having good quality, soft rubber will be an advantage.
- Batman
Re: "Eva-Ann"
Thanks for the tip.73type2 wrote: Mon Mar 11, 2019 2:10 pm It is best to do the job on a nice sunny day. Having good quality, soft rubber will be an advantage.
Will youtube a bit
Re: "Eva-Ann"
I see you've got Cal-look rubbers, so it should be even easier to install. It is also better to cut out the old rubber rather than try to save it. I've learnt this the hard way!
- Batman
Re: "Eva-Ann"
Front one has got the beading. (looks like the original rubber)
Going to collect the rubber this afternoon from Pro-Auto rubber. Only R313.95
- Riaan.N
- Oil Seal
- Has thanked: 3 times
- Been thanked: 38 times
Re: "Eva-Ann"
Me and my wife replaced the front wind screen on our beetle. Man, that was not so easy[emoji3061] BUT we did it!
I used a thin rope and when I have to do it again I’ll get a thicker rope.
We had to apply a lot of pressure from the outside in and from the top pushing down and keep it applied otherwise the rubber does not give and the window pops out.
I have one of those shoe fitting spoon tools and that helped a lot with coaxing the rubber into where it must go.
I also used Pro Auto rubber. I will put all the chrome beading back when the beetle has been resprayed at some stage. Will then look at using Wolfsburg West rubbers.
