Re: 2.0 KCC 356 Porsche Speedster
Posted: Wed Oct 24, 2012 9:37 am
Had a good day yesterday.
Pulled the last of the harness through. This is all tucked up high against the firewall, so that you won't see anything. The cables will be attached with extra P-clamps that I have lying around. At R12 each, I'm planning on using all the old ones that I had left over. I also got my cover for the expansion tank in place to clean things up.
Decided to start on the scoop for the front. This thing looks huge. I had some hardboard that I mocked up to the right size and then hot glued the lot together. After this weekend I can get an idea of how much of the lower section of the bumper will have to be trimmed. At the end of the day, I'll have a radiator opening about 40cm x 10cm.
And how much of this do you exactly see when the bumper is back on?
Obviously the bumper section will be trimmed below the belt line, but the scoop, (which will be made in 1mm galvanised plate) and then painted black will be able to poke through. Very chuffed with how non-evasive the install looks. A few little projects to kill before the weekend, but we're getting there.
