Page 43 of 122
Posted: Sun Mar 31, 2013 12:20 am
by chrisradioman
My daughter loves the rust bus:-
Posted: Sun Mar 31, 2013 12:21 am
by chrisradioman
Got my new seat, very good quality, I need to modify it now so it fits.:D
Got my new Genuine German Bosch Coil today.:D
Posted: Sun Mar 31, 2013 12:23 am
by chrisradioman
Called in to see Tudor today. He's got all of my bits ready for the final clean, its surprising how clean everything is looking. Most of the parts could be passed off for new.
I think he's starting the build tonight, after Mike has fly cut the heads & put the new guides in, at the same time he's putting new studs in:-
Posted: Sun Mar 31, 2013 12:32 am
by chrisradioman
Yesterday I drove a lovely Bay window double cab pick up down to Carmarthen town centre to help promote the Volksfest Wales show first weekend in August, we had a fantastic response & the weather stayed dry.
Posted: Sun Mar 31, 2013 12:34 am
by chrisradioman
Called in to See Tudor Morgan today to drop off my pick up pipe, you can see its much longer than the old one-
This is the baffle plate that is usually missing from type 4 engines:-
This side of the case is now all ready to go, just needs a last clean:-
Tudor noticed this crack in 1 of the cylinders so its scrap & he'll use a different one.:-
Tudor has been busy on the engine all weekend, it turns out the Porsche case has been previously machined for oversize bearings & he has bought standard size bearings to suit the crank. He's decided to use the 412 case instead, so its a bit of a set back, the pick up pipe set him back as well so did the cracked cylinder. Its a good job he's checking everything so thoroughly. Its much better to find it now than latter.
The heads are ready so are the cylinders & pistons & they look really good.
Posted: Sun Mar 31, 2013 12:37 am
by chrisradioman
Tudor wasn't happy with my intake pipe seals, the rubber inside is starting to perish & could pull in air, I bought a 300mm long 35mm id silicone hose spec:-
Max Working Pressure 5 Bar (70psi)
Hose Temp range -50°C(-58°F) to 170°C(338°F)
Wall Thickness 4.5mm
Construction 4 Ply Polyester Silicone.
Posted: Sun Mar 31, 2013 12:39 am
by chrisradioman
The case is now ready for its final clean & then reassembly:-
Posted: Sun Mar 31, 2013 12:43 am
by chrisradioman
Posted: Sun Mar 31, 2013 12:45 am
by chrisradioman
We have a visitor for the next week, its a very early bay prototype lol.
It's a genuine 42K miles 21 window Samba:-
I'm wiring in an electric hook up & a leisure battery. I'm also going to check over the wiring, the front fog lights don't work, neither do the brake lights. I'm also fitting an alternator instead of the dynamo. Come the winter Tudor will be rebuilding the engine. Its still got the original engine & its never been rebuilt. It still runs nice but Jonathan wants to make sure it is good for years to come.:D
Posted: Sun Mar 31, 2013 12:48 am
by chrisradioman
Tudor Morgan has now had some success with the engine & everything is now going to plan, things are moving on now. Crank all built up with gears, mains and new big ends, conrods free falling correctly.
Crank shaft and cam shaft (with new bearings) fitted to lower half of
case.
Cases sealed both sides and brought together, fitted with windage plate and all bolts torqued to the spec.
Its now just fit the barrels & pistons, the heads, ancillaries & tinware.
I can see light at the end of the tunnel.
Posted: Sun Mar 31, 2013 12:49 am
by chrisradioman
This is my drive before we left for Dubs at the castle:-
Posted: Sun Mar 31, 2013 12:50 am
by chrisradioman
Bought myself a centre seat from Bluebird Customs. It will need some modification as I only have one bulkhead but I'm sure I can work something out.:D
More pictures of our weekend at Dubs at the Castle:-
Posted: Sun Mar 31, 2013 12:51 am
by chrisradioman
Posted: Sun Mar 31, 2013 12:54 am
by chrisradioman
by chrisradioman
