Help rescue a Bay Camper - please
Klaus
Post by Klaus »
Please post progress pics of the door card trimming as you get to it
Good luck - envious !
didi
Been thanked: 37 times
Post by didi »
I got some peelply from the mattress shop and some material (the wife's choice)
I wanted to install it, but first had to sort out the window scrapers and 1/4 vent rubbers. Each time it rained, water was pouring into the doors.
_______
didi
Post by didi »
I have hazards and lights
_______
louisvr45
Re: Help rescue a Bay Camper - please
Post by louisvr45 »
hi tel us how you covered and fasten the door pannels? I still need to cover mine.
didi
Post by didi »
I drilled 10mm holes like the original template and used the original clips. There were some clips that broke and I got replacements from Volkspares.
I also replaced the inner doorhandles window winders with new ones.
Andries Groenewald was so kind to take off the kickpannels off his bus so that I can make templates. Thanks Andries, you saved me a lot of time!
_______
Klaus
Post by Klaus »
Any updates Didi?
buggyfan
Long Block
Has thanked: 95 times
Been thanked: 87 times
Post by buggyfan »
didi wrote:I drilled 10mm holes like the original template and used the original clips.!
:hangloose: :hangloose:
+1 for going that route,theres nothing worse than a newly upholstered interior where the door panels get attached with self tappers :jerkoff: :jerkoff:
didi
Post by didi »
I am in Cape Town at the moment. I plan to continue working on the bus next week when I am back home. It has to be ready for the KKK campout in Feb.
There is still lots to do. I will post as soon as any progress happens.
_______
Colin
What model do you have?: 1975 transporter
Post by Colin »
louisvr45 wrote:hi tel us how you covered and fasten the door pannels? I still need to cover mine.
When i done my interior i re cut all of the panels out of masonite used the original clips on the front doors couldn’t find new ones anywhere and i replaced most of the clips on the other panels with other straight clips. i put a thin foam and then material and stapled it around the edges at the back with the shortest staples a could . Sorry i didn’t take pics at this stage of my restoration only got a pic of how it looks now.
didi wrote:I am in Cape Town at the moment. I plan to continue working on the bus next week when I am back home. It has to be ready for the KKK campout in Feb.
Where about in Cape Town - planning any trips to the Paarl area - pull in for a cuppa ?
Has thanked: 423 times
Been thanked: 542 times
You will find all the clips and plastic plugs at a Wurth store look in phone book.......
didi
Post by didi »
I got the rear taillights working tonight. Image
_______
Junior
Post by Junior »
Nice work coming on there :hangloose: :hangloose: You have got your self a nice bus right there :hangloose: :hangloose:
Klaus
Post by Klaus »
Looking good.
You must be so proud to have rescued her from certain demise and in the not too distant future she will be cruising the streets and helping you and your family on many adventures.... Truly awesome !
didi
Post by didi »
Thanks for the kind words guy's. It feels like I'm finally getting there.
I made a place for the spin on oil filter just behind the mudguard where it's out of harms way from rocks.
And I made a box out of a Indy oil drum to close the engine bay off
_______
