Whispers from The DarkSide 11 : TieFighter PG18!!h
- vader
- Has thanked: 9 times
Re: Whispers from The DarkSide 11 : TieFighter PG18!!h
Update..
Last week I went to JMZ's (Jedi Master Z... Duh!!) And finally finally ported the TP Heads!!! Must say that they looking WICKED!!! 456 but they are gonna kick ass!!!
But the real BIG news is that TF is being cut and remoulded at the boat shop so I will get IT back tomorrow all aligned, remolded and droped in front....super sexy!!! Fcuk I cant wait. After that its the roll cage, doors. windows and engine!!! then ZOOOOOOOMMMMM ZOOOOOOMMMM ZOOOOOOOOMMMMM!!!!! and then a whole shitload of more work.........
- hitlers revenge
- Been thanked: 36 times
Useless without pictures
- vader
Just like a passenger seat without a Seatcover....
- vader
Decided not to cut and drop the front as I would have had streagth issues but it done and ready to be bolted down and have the roll cage assembled... Then I can look at the door hinges, I know Tony, I know.... i am also planning to ClearGell the body Black so that when its sprayed and gets a scratch the white wont show.. The boat builders will do that for me aswell and at the same time fit the rear wing from DaveR, a German look front spoiler, re-worked FR wheel arcs and an Orange on the ariel...
Now I wish I could get over this flu been 5 days in bed and still sick...
- MarshallGTi
- Camshaft
- Has thanked: 7 times
- Been thanked: 11 times
wheres the pix?
Ryan Marshall
- vader
As Vader isnt updating anything, I'll report that the two of us have been making a little slow progress on the 1915 engine for the Tie fighter.
Nothing special, but making progress.
He seems to spend more time getting his gas mixture right than anything else.....
Anyway, bottom end is together, heads are ported, valves lapped in, 3 angle valve grind done, barrels decked correctly, heads assembled... I think the next step is to begin putting the long block together. O yes, still need to set endplay.... next week maybe?
NICE....with the plastic body its going to go like stink.....
Will need big balls to keep the front down.
- vader
Thanks Tony further update need to add a 4th shim to bring the end play closer to 0.1... Somewhere along the line my grand nut got swopped and one relief velve went missing!?!?! Also need TP tin as I have upgraded to Twin ports!!! Extra power is never enough!!!
Thanks for the help MJZ.....
- vader
- vader
Can anyone help me out with an A-Frame to tow TF to my house in Gordons Bay? About 5 km?
Can bring one down on the 15/09/2012, unless its too late ??
just ask.
just ask.
- Barry
- Single Port
- Been thanked: 12 times
I made a quick & dirty one up to collect a project that I ended up not buying. You are welcome to use it. Give me a holler 083 461 3493
Barry
- vader
Thanks Barry Ill give you a call soon...
- vader
Ok here is the pics of the cut...
