Warwicks Split
- sean
- Has thanked: 63 times
- Been thanked: 227 times
Re: Warwicks Split
You made a good move there!
Will be posting some progress pics of my bus soon with all the green repair panels. It's really money well spent.
Warwick-Lowlight
- Been thanked: 14 times
Re: Warwicks Split
Shot sean
I'm sorry I could not make it yesterday - would have loved some quality time with the Green Doc and yourself -Im sure there were some fine details that the man parted with
Ya definately money well spent - those panels fit like a glove
might even look at some more
Front frame repair section etc
I mean if your not going all the way then why go at all !!
Warwick-Lowlight
Warwick-Lowlight
Re: Warwicks Split
That was the idea but thought I would have a look at the bearings
Glad i did cause they are all a bit rough
While its open lets doo the whole lot
So off to bearing guys in town to see what we can get
By lowlightwarwick at 2012-08-10
Warwick-Lowlight
Re: Warwicks Split
Well what a weekend
Splitbussaholics visit and panels making me sleep not so nice - burning holes in all that good green stuff with a stick welder
So what a suprise when doing some junking
-found a mig - loose tools and a boot carrier rack all for 2 k
Wife not very happy with the spending but alas the job must continue
Have a mate that is going to buy the mig when Im done for 3 k
Saw a google sales pith at builders for 7 k ??????
Got the tierod ens from our local for zar 308 for 4
L and r thread for the moving parts
on the stattic - will thread the one side and weld the other in
yes you guesed - will use the mig to do that
Also got all the bearings for the Red boxes - zar 920 for all 8 and the are premium quality
will put up the numbers a little later
Why is it when you deal with the regular splitt parts suppliers they all think you are super $$$$$ so an extra 1 on all will suffice
trying the old school method of deal direct - maybe we can all save some $$$$ this way
The parts are out there you just have too look
MIG here we go
By lowlightwarwick at 2012-08-12
new bearings in place
Now all i need are the seals
might even make some myself - maybe take to long
\So FFR will be getting a call
MIG here we go
Warwick-Lowlight
Re: Warwicks Split
Those of you in the know will spot the problem in this photo
will put it up and see what we get
HASTIG WAS NOOIT DIE BAAS
MAIN SHAFT DOES NOT FIT THIS WAY
only one way to learn hey
- Ron&Gill
- Been thanked: 21 times
Re: Warwicks Split
Ja-ja, that 3605(? 3505?) bearing goes on last... It's actually in a post on Gill's bus.
- sean
Re: Warwicks Split
Hey Warwick!! It's a race to see who's bus is on the road first.
By the looks of things, I am ahead!
Unfortunately for Jolas, since last month he has fallen behind...
Warwick-Lowlight
Re: Warwicks Split
Hey dude go easy
Tools in workshoppe pitter pattering around is easy to deal with
Just wait for the pitter patter of small feet
Tell you what a complete reck of a bus is easier than that lott
Paul is strong and will join the Cape Rat Pack soon
Ja will be good when the "Fleet" has an open day Tour
Hopefully a Summer mission to DeHoop will be an idea
- sean
Re: Warwicks Split
Common Paul, you must join.
Warwick-Lowlight
- sean
Re: Warwicks Split
Make sure the tie-rod end doesn't get hot while you do this, it needs to be submerged in a coolant, if not, all the plastics will melt inside and cause the end to fail.Warwick-Lowlight wrote:Well what a weekend
You didn't mention the drag link, these ends are also available from Midas, same as the Baywindow.
Warwick-Lowlight
Re: Warwicks Split
Got you Sean
Heat and rubber no good
Will look and see if my mate can turn me a L hand tread then no need for the heat
Drag link must have been replaced as its still solid - that is the ends
Will just take off the rubber covers and renew and put some grease in there
Warwick-Lowlight
Re: Warwicks Split
OK this coffee is starting to taste tooo good
Need to sleep now
You peoples out there need some chickens in the morning
4 Am here we come
maybe I should put up the correct config of the reduction bearings
Need to sleep now
4 Am here we come
- jolas
- Has thanked: 393 times
- Been thanked: 173 times
Re: Warwicks Split
Eish you bugger, I hope you have twins or triplets 1st time aroundsean wrote:Hey Warwick!! It's a race to see who's bus is on the road first.![]()
By the looks of things, I am ahead!Unfortunately for Jolas, since last month he has fallen behind...
